Klipper Filament Sensor
How do you manage klipper filament sensor with repetier-server ?
Edouard
  • Good question. There is no official solution due to klipper flexibility. If you enable respond module in klipper
    [respond]
    default_type: echo
    You can send a message that server can capture like:
    RESPOND MSG="outOfFilament"
    So if you watch for the response in server firmwarfe response definition you can add for that rule
    @outOfFilament
    to pause and open filament change.
    You need to modify
    [filament_switch_sensor my_sensor]
    section so
    pause_on_runout: False # When set to True, a PAUSE will execute immediately after a runout # is detected. Note that if pause_on_runout is False and the # runout_gcode is omitted then runout detection is disabled. Default # is True. runout_gcode: RESPOND MSG="outOfFilament"
    That should close the signal queue from klipper to server so server does handle the stop.
