issues with printer
i have updated laptop and ever since i have been unable to print i can connect put doesn't know what printer is connected i am new to 3d printing so only use the app and not the sever here are some of the errors i am getting
11:36:45.091 : OpenGL version:4.6.0 - Build 31.0.101.4091
11:36:45.091 : OpenGL extensions:GL_3DFX_texture_compression_FXT1 GL_AMD_depth_clamp_separate GL_AMD_vertex_shader_layer GL_AMD_vertex_shader_viewport_index GL_ARB_ES2_compatibility GL_ARB_ES3_1_compatibility GL_ARB_ES3_compatibility GL_ARB_arrays_of_arrays GL_ARB_base_instance GL_ARB_bindless_texture GL_ARB_blend_func_extended GL_ARB_buffer_storage GL_ARB_cl_event GL_ARB_clear_buffer_object GL_ARB_clear_texture GL_ARB_clip_control GL_ARB_color_buffer_float GL_ARB_compatibility GL_ARB_compressed_texture_pixel_storage GL_ARB_compute_shader GL_ARB_conditional_render_inverted GL_ARB_conservative_depth GL_ARB_copy_buffer GL_ARB_copy_image GL_ARB_cull_distance GL_ARB_debug_output GL_ARB_depth_buffer_float GL_ARB_depth_clamp GL_ARB_depth_texture GL_ARB_derivative_control GL_ARB_direct_state_access GL_ARB_draw_buffers GL_ARB_draw_buffers_blend GL_ARB_draw_elements_base_vertex GL_ARB_draw_indirect GL_ARB_draw_instanced GL_ARB_enhanced_layouts GL_ARB_explicit_attrib_location GL_ARB_explicit_uniform_location GL_ARB_fragment_coord_conventions GL_ARB_fragment_layer_viewport GL_ARB_fragment_program GL_ARB_fragment_program_shadow GL_ARB_fragment_shader GL_ARB_fragment_shader_interlock GL_ARB_framebuffer_no_attachments GL_ARB_framebuffer_object GL_ARB_framebuffer_sRGB GL_ARB_geometry_shader4 GL_ARB_get_program_binary GL_ARB_get_texture_sub_image GL_ARB_gl_spirv GL_ARB_gpu_shader5 GL_ARB_gpu_shader_fp64 GL_ARB_half_float_pixel GL_ARB_half_float_vertex GL_ARB_indirect_parameters GL_ARB_instanced_arrays GL_ARB_internalformat_query GL_ARB_internalformat_query2 GL_ARB_invalidate_subdata GL_ARB_map_buffer_alignment GL_ARB_map_buffer_range GL_ARB_multi_bind GL_ARB_multi_draw_indirect GL_ARB_multisample GL_ARB_multitexture GL_ARB_occlusion_query GL_ARB_occlusion_query2 GL_ARB_pipeline_statistics_query GL_ARB_pixel_buffer_object GL_ARB_point_parameters GL_ARB_point_sprite GL_ARB_polygon_offset_clamp GL_ARB_post_depth_coverage GL_ARB_program_interface_query GL_ARB_provoking_vertex GL_ARB_query_buffer_object GL_ARB_robust_buffer_access_behavior GL_ARB_robustness GL_ARB_robustness_isolation GL_ARB_sample_shading GL_ARB_sampler_objects GL_ARB_seamless_cube_map GL_ARB_seamless_cubemap_per_texture GL_ARB_separate_shader_objects GL_ARB_shader_atomic_counter_ops GL_ARB_shader_atomic_counters GL_ARB_shader_bit_encoding GL_ARB_shader_draw_parameters GL_ARB_shader_group_vote GL_ARB_shader_image_load_store GL_ARB_shader_image_size GL_ARB_shader_objects GL_ARB_shader_precision GL_ARB_shader_stencil_export GL_ARB_shader_storage_buffer_object GL_ARB_shader_subroutine GL_ARB_shader_texture_image_samples GL_ARB_shading_language_100 GL_ARB_shading_language_420pack GL_ARB_shading_language_packing GL_ARB_shadow GL_ARB_spirv_extensions GL_ARB_stencil_texturing GL_ARB_sync GL_ARB_tessellation_shader GL_ARB_texture_barrier GL_ARB_texture_border_clamp GL_ARB_texture_buffer_object GL_ARB_texture_buffer_object_rgb32 GL_ARB_texture_buffer_range GL_ARB_texture_compression GL_ARB_texture_compression_bptc GL_ARB_texture_compression_rgtc GL_ARB_texture_cube_map GL_ARB_texture_cube_map_array GL_ARB_texture_env_add GL_ARB_texture_env_combine GL_ARB_texture_env_crossbar GL_ARB_texture_env_dot3 GL_ARB_texture_filter_anisotropic GL_ARB_texture_float GL_ARB_texture_gather GL_ARB_texture_mirror_clamp_to_edge GL_ARB_texture_mirrored_repeat GL_ARB_texture_multisample GL_ARB_texture_non_power_of_two GL_ARB_texture_query_levels GL_ARB_texture_query_lod GL_ARB_texture_rectangle GL_ARB_texture_rg GL_ARB_texture_rgb10_a2ui GL_ARB_texture_stencil8 GL_ARB_texture_storage GL_ARB_texture_storage_multisample GL_ARB_texture_swizzle GL_ARB_texture_view GL_ARB_timer_query GL_ARB_transform_feedback2 GL_ARB_transform_feedback3 GL_ARB_transform_feedback_instanced GL_ARB_transform_feedback_overflow_query GL_ARB_transpose_matrix GL_ARB_uniform_buffer_object GL_ARB_vertex_array_bgra GL_ARB_vertex_array_object GL_ARB_vertex_attrib_64bit GL_ARB_vertex_attrib_binding GL_ARB_vertex_buffer_object GL_ARB_vertex_program GL_ARB_vertex_shader GL_ARB_vertex_type_10f_11f_11f_rev GL_ARB_vertex_type_2_10_10_10_rev GL_ARB_viewport_array GL_ARB_window_pos GL_ATI_separate_stencil GL_EXT_abgr GL_EXT_bgra GL_EXT_blend_color GL_EXT_blend_equation_separate GL_EXT_blend_func_separate GL_EXT_blend_minmax GL_EXT_blend_subtract GL_EXT_clip_volume_hint GL_EXT_compiled_vertex_array GL_EXT_depth_bounds_test GL_EXT_direct_state_access GL_EXT_draw_buffers2 GL_EXT_draw_range_elements GL_EXT_fog_coord GL_EXT_framebuffer_blit GL_EXT_framebuffer_multisample GL_EXT_framebuffer_object GL_EXT_geometry_shader4 GL_EXT_gpu_program_parameters GL_EXT_gpu_shader4 GL_EXT_memory_object GL_EXT_memory_object_win32 GL_EXT_multi_draw_arrays GL_EXT_packed_depth_stencil GL_EXT_packed_float GL_EXT_packed_pixels GL_EXT_polygon_offset_clamp GL_EXT_rescale_normal GL_EXT_secondary_color GL_EXT_semaphore GL_EXT_semaphore_win32 GL_EXT_separate_specular_color GL_EXT_shader_framebuffer_fetch GL_EXT_shader_integer_mix GL_EXT_shadow_funcs GL_EXT_stencil_two_side GL_EXT_stencil_wrap GL_EXT_texture3D GL_EXT_texture_array GL_EXT_texture_compression_s3tc GL_EXT_texture_edge_clamp GL_EXT_texture_env_add GL_EXT_texture_env_combine GL_EXT_texture_filter_anisotropic GL_EXT_texture_integer GL_EXT_texture_lod_bias GL_EXT_texture_rectangle GL_EXT_texture_sRGB GL_EXT_texture_sRGB_decode GL_EXT_texture_shared_exponent GL_EXT_texture_snorm GL_EXT_texture_storage GL_EXT_texture_swizzle GL_EXT_timer_query GL_EXT_transform_feedback GL_IBM_texture_mirrored_repeat GL_INTEL_conservative_rasterization GL_INTEL_fragment_shader_ordering GL_INTEL_framebuffer_CMAA GL_INTEL_map_texture GL_INTEL_multi_rate_fragment_shader GL_INTEL_performance_query GL_KHR_blend_equation_advanced GL_KHR_blend_equation_advanced_coherent GL_KHR_context_flush_control GL_KHR_debug GL_KHR_no_error GL_KHR_shader_subgroup GL_KHR_shader_subgroup_arithmetic GL_KHR_shader_subgroup_ballot GL_KHR_shader_subgroup_basic GL_KHR_shader_subgroup_clustered GL_KHR_shader_subgroup_quad GL_KHR_shader_subgroup_shuffle GL_KHR_shader_subgroup_shuffle_relative GL_KHR_shader_subgroup_vote GL_KHR_texture_compression_astc_ldr GL_NV_blend_square GL_NV_conditional_render GL_NV_primitive_restart GL_NV_texgen_reflection GL_OVR_multiview GL_SGIS_generate_mipmap GL_SGIS_texture_edge_clamp GL_SGIS_texture_lod GL_SUN_multi_draw_arrays GL_WIN_swap_hint WGL_EXT_swap_control
11:36:45.091 : OpenGL renderer:Intel(R) Iris(R) Xe Graphics
11:36:45.091 : Using fast VBOs for rendering is possible
11:36:45.408 : import zipped amf file
11:36:45.440 : Starting object analyser ...
11:36:45.440 : Object is manifold.
11:36:45.440 : Analysing finished.
11:37:17.861 : The port 'COM1' does not exist.
11:37:29.366 : The parameter is incorrect.
11:37:29.366 :
11:37:42.346 : No start signal detected - forcing start
11:37:42.368 : N1 M110*34
11:37:42.368 : N2 M115*36
11:37:42.368 : N3 M105*36
11:37:42.368 : N4 M114*35
11:37:42.368 : N5 M111 S6*98
11:37:42.368 : N6 T0*60
11:37:42.368 : N7 M20*22
11:37:42.368 : N8 M80*19
11:37:42.368 : N9 M105*46
11:37:45.454 : N10 M105*22
11:38:20.814 : No start signal detected - forcing start
11:38:20.814 : N1 M110*34
11:38:20.814 : N2 M115*36
11:38:20.814 : N3 M105*36
11:38:20.814 : N4 M114*35
11:38:20.814 : N5 M111 S6*98
11:38:20.814 : N6 T0*60
11:38:20.814 : N7 M20*22
11:38:20.814 : N8 M80*19
11:38:23.917 : N9 M105*46
11:38:27.011 : N10 M105*22
11:39:07.052 : Communication timeout - reset send buffer block
11:39:07.052 : N11 M105*23
11:39:10.134 : N12 M105*20
11:39:13.193 : N13 M105*21
11:39:15.364 : N14 M104 T0 S200*22
11:39:16.289 : N15 M105*19
11:39:19.392 : N16 M105*16
11:39:22.496 : N17 M105*17
11:39:25.604 : N18 M105*30
11:39:28.708 : N19 M105*31
11:40:08.749 : Communication timeout - reset send buffer block
11:40:08.749 : N20 M105*21
11:40:11.732 : N21 M105*20
11:40:14.800 : N22 M105*23
11:40:17.875 : N23 M105*22
11:40:20.981 : N24 M105*17
11:40:24.078 : N25 M105*16
11:40:27.164 : N26 M105*19
11:40:30.247 : N27 M105*18
11:40:33.347 : N28 M105*29
11:40:59.261 : No start signal detected - forcing start
11:40:59.277 : N1 M110*34
11:40:59.277 : N2 M115*36
11:40:59.277 : N3 M105*36
11:40:59.277 : N4 M114*35
11:40:59.332 : N5 M111 S6*98
11:40:59.332 : N6 T0*60
11:40:59.332 : N7 M20*22
11:40:59.332 : N8 M80*19
11:40:59.332 : N9 M105*46
11:41:02.347 : N10 M105*22
11:41:42.401 : Communication timeout - reset send buffer block
11:41:42.401 : N11 M105*23
11:41:45.496 : N12 M105*20
11:41:48.562 : N13 M105*21
11:41:51.569 : N14 M105*18
11:41:54.633 : N15 M105*19
11:41:57.741 : N16 M105*16
11:42:00.821 : N17 M105*17
11:42:03.934 : N18 M105*30
11:42:07.020 : N19 M105*31
11:42:47.085 : Communication timeout - reset send buffer block
11:42:47.085 : N20 M105*21
11:42:49.986 : N21 M105*20
11:42:52.971 : N22 M105*23
11:42:55.998 : N23 M105*22
11:42:59.052 : N24 M105*17
11:43:02.139 : N25 M105*16
11:43:05.221 : N26 M105*19
11:43:08.300 : N27 M105*18
11:43:11.383 : N28 M105*29
11:43:51.459 : Communication timeout - reset send buffer block
11:43:51.459 : N29 M105*28
11:43:54.555 : N30 M105*20
11:43:57.659 : N31 M105*21
11:44:00.745 : N32 M105*22
11:44:03.832 : N33 M105*23
11:44:06.935 : N34 M105*16
11:44:10.012 : N35 M105*17
11:44:13.084 : N36 M105*18
11:44:16.162 : N37 M105*19
11:44:56.242 : Communication timeout - reset send buffer block
11:44:56.242 : N38 M105*28
11:44:59.252 : N39 M105*29
11:45:02.328 : N40 M105*19
11:45:05.419 : N41 M105*18
11:45:08.501 : N42 M105*17
11:45:11.600 : N43 M105*16
11:45:14.690 : N44 M105*23
11:45:17.788 : N45 M105*22
11:45:20.790 : N46 M105*21
11:46:00.890 : Communication timeout - reset send buffer block
11:46:00.890 : N47 M105*20
11:46:00.894 : N48 M104 T0 S200*31
11:46:03.905 : N49 M105*26
11:46:07.011 : N50 M105*18
11:46:10.105 : N51 M105*19
11:46:13.111 : N52 M105*16
11:46:16.120 : N53 M105*17
11:46:19.194 : N54 M105*22
11:46:22.298 : N55 M105*23
11:47:02.356 : Communication timeout - reset send buffer block
11:47:02.356 : N56 M105*20
11:47:05.468 : N57 M105*21
11:47:08.547 : N58 M105*26
11:47:11.629 : N59 M105*27
11:47:14.713 : N60 M105*17
11:47:17.793 : N61 M105*16
11:47:20.866 : N62 M105*19
11:47:23.952 : N63 M105*18
11:47:27.039 : N64 M105*21
11:48:07.083 : Communication timeout - reset send buffer block
11:48:07.083 : N65 M105*20
11:48:10.076 : N66 M105*23
11:48:13.150 : N67 M105*22
11:48:16.252 : N68 M105*25
11:48:19.343 : N69 M105*24
11:48:22.441 : N70 M105*16
11:48:25.539 : N71 M105*17
11:48:28.620 : N72 M105*18
11:48:31.712 : N73 M105*19
11:49:11.736 : Communication timeout - reset send buffer block
11:49:11.736 : N74 M105*20
11:49:14.631 : N75 M105*21
11:49:17.735 : N76 M105*22
11:49:20.815 : N77 M105*23
11:49:23.927 : N78 M105*24
11:49:26.930 : N79 M105*25
11:49:30.016 : N80 M105*31
11:49:33.116 : N81 M105*30
11:49:36.183 : N82 M105*29
11:50:16.216 : Communication timeout - reset send buffer block
11:50:16.216 : N83 M105*28
11:50:19.329 : N84 M105*27
11:50:22.415 : N85 M105*26
11:50:25.502 : N86 M105*25
11:50:28.601 : N87 M105*24
11:50:31.608 : N88 M105*23
11:50:34.683 : N89 M105*22
11:50:37.760 : N90 M105*30
11:50:40.791 : N91 M105*31
11:51:20.819 : Communication timeout - reset send buffer block
11:51:20.819 : N92 M105*28
11:51:23.695 : N93 M105*29
11:51:26.759 : N94 M105*26
11:51:29.839 : N95 M105*27
11:51:32.920 : N96 M105*24
11:51:36.023 : N97 M105*25
11:51:39.105 : N98 M105*22
11:51:42.124 : N99 M105*23
11:51:45.221 : N100 M105*38
11:52:25.224 : Communication timeout - reset send buffer block
11:52:25.224 : N101 M105*39
11:52:28.338 : N102 M105*36
11:52:31.427 : N103 M105*37
11:52:34.510 : N104 M105*34
11:52:37.603 : N105 M105*35
11:52:40.711 : N106 M105*32
11:52:43.784 : N107 M105*33
11:52:43.784 : Serial com error:System.IO.Ports.SerialErrorReceivedEventArgs
11:52:46.846 : N108 M105*46
11:52:49.934 : N109 M105*47
11:53:30.028 : Communication timeout - reset send buffer block
11:53:30.028 : N110 M105*39
11:53:33.147 : N111 M105*38
11:53:36.232 : N112 M105*37
11:53:39.310 : N113 M105*36
11:53:42.403 : N114 M105*35
11:53:45.405 : N115 M105*34
11:53:48.478 : N116 M105*33
11:53:51.483 : N117 M105*32
11:53:54.555 : N118 M105*47
11:54:34.563 : Communication timeout - reset send buffer block
11:54:34.564 : N119 M105*46
11:54:37.539 : N120 M105*36
11:54:40.602 : N121 M105*37
11:54:43.656 : N122 M105*38
11:54:46.760 : N123 M105*39
11:54:46.762 : Serial com error:System.IO.Ports.SerialErrorReceivedEventArgs
11:54:46.763 : Serial com error:System.IO.Ports.SerialErrorReceivedEventArgs
11:54:46.764 : Serial com error:System.IO.Ports.SerialErrorReceivedEventArgs
11:54:46.770 : Serial com error:System.IO.Ports.SerialErrorReceivedEventArgs
11:54:49.860 : N124 M105*32
11:54:52.930 : N125 M105*33
11:54:55.986 : N126 M105*34
11:54:59.094 : N127 M105*35
11:55:39.128 : Communication timeout - reset send buffer block
11:55:39.128 : N128 M105*44
11:55:42.087 : N129 M105*45
11:55:45.177 : N130 M105*37
11:55:48.239 : N131 M105*36
11:55:51.307 : N132 M105*39
11:55:54.371 : N133 M105*38
11:55:57.438 : N134 M105*33
11:56:00.460 : N135 M105*32
11:56:03.558 : N136 M105*35
Looks like you have configured it to use COM1 which does not exist. See the dropdown which exists. Most have only one port in the list. The port will only appear if printer is powered and usb driver is installed for the printer board, also since W10 most get installed automatically.
Next is then selectiong right baud rate. As you see from log you get lots of timeouts because there is communication. If this happens with correct port it is the baud rate normally being wrong. 115200 and 250000 are the one used in 99% of printer.
