Generated G-code not found
Ok, so I'm having a fun time with the BEST game ever.
For whatever reason, when I'm trying to do a slice with Prusaslicer, and I've gotten nothing but the
Generated G-Code Not F:ound.
But wait, there's more.
This only happens on occasion. If I close and re-open the software a couple dozen times, or I restart my entire computer, then it'll work just fine, without any issues.
I have no clue how I even managed this. I'm running Ubuntu 22.04, and I've got the latest version of each software needed. Little help?
Design is a simple 3" disk, .175 in thick, for Garmin Vacuum base. I intend to use the smooth side from the class on the bead for the vacuum side and stick the disk to the dash of my truck with double sided tape.
I've been using Fusion 360 with Repetier Host for years and never had this problem before. I always update Host to the latest version...
BTW, I get the same error using Slic3r, Prussia Slic3r, and Cura Engine provided with Repetier Host.
