how to down IDE to arduino board
I am new, I had download repeater host mac ,hard time to config the printer set up(different panel than instruction)
and how to download IDE to my gadget 30D Ramps 1.4 arduino board
Thank you
  • Sounds liek you used the windows host docs not the mac documentation.
    For firmware installation see http://www.repetier.com/documentation/repetier-firmware/rf-installation/ and maybe try our firmware config tool.
  • This is what I get,after unzip the
    http://arduino.cc/en/Main/Software        void setup() {
      // put your setup code here, to run once:
    void loop() {
      // put your main code here, to run repeatedly:
    different than your instruction
  • on top of the panel I have doesn't have the
    Skatch  tool  help is different
  • The image is from an older Arduino IDE. You need to open the firmware you want to compile of course. The default sketch is just if you want to program your own software.
