Filament Runout: Filament change is triggered even if not printing (printers blocked)
I‘m using the Pro version 1.4.9. I have multiple printers connected, many of them with filament sensors configured. After an update from 1.4.6 (? maybe earlier, but definitely 1.4.x) the printers behave incorrectly. After startup, if there is no filament, the filament change is immediately triggered. While the nozzle heats up, no communication with the printer is possible. If I start up the printers without the usb connection, all is fine.
If I disable the filament sensor (M412 S0), the connection works. However, it seems that the behavior of Repetier Server has changed with one of the latest changes. I have been working with my setup for quite some time with different Marlin versions, but this didn’t happen before.
This behavior can be observed independently of whether M412 H is set to 0 or 1, also with Marlin versions 2.0.9.x and 2.1.x.
Can you please check what the issue is? Do you have an idea? I really like the host action to change the filament, but it should be only triggered when printing, not always.
Thanks! Thomas
Thanks! Thomas
Problem is we need these commands since some versions can not cope with M75 with filename so we need to test if it is supported on startup. So question is if this has the sideeffect you describe. Comment the 2 lines with semicolon and restart server and see if it still triggers this. Maybe I could add a delay on startup to ignore it directly at connect.
yes, commenting out those two lines did the trick. Can you explain why the test is needed? I would expect that most (all?) Marlin versions with a runout sensor will behave this way. Does it make sense to have a config where you can chooses whether this test is executed for Marlin-based printers? Or maybe let the user just „confirm“ whether the option is there or not. Or which type of M75 he wants to use.
One more reason why I think running the print timer in Marlin just as a test is not such a good idea: some procedures are coupled to the print timer, e.g. print statistics. They collect information on how many prints were made with the printer. „Running“ a print on every connection would basically make this information useless. For me, the print statistics are not relevant, but making Marlin think that a print is started „just for testing something“ seems to be not such a good idea to me. Please consider removing the check and introducing a configuration item for Marlin-based printers instead.
Thanks! Thomas
So this is a dilemma and I think I need to remove sending filenames on M75 like before. It has already caused so much troubles it is not worth knowing the file you print on printers with support. They can add a replacement if they like then. In that case I can also omit the test.
Thanks for testing and extra info with statistics. Never saw it on my printers.
