Home Assistant 2023.3
This is more of a heads-up than a support ticket.
I found that after upgrading to Home Assistant 2023.3.1, MQTT was throwing some errors relating to my printers and none of my printer sensors were active. Quick fix is to change the default MQTT version in Repeter Server (3.1.1 with fallback to 3.1) to version 5.
Hope this helps someone else who has the same issue.
