installation failed on debian 7 (wheezy)
Hi folks,
todays installation on debian 7 failed with following error:
root@repetierserver:~/download# dpkg -i Repetier-Server-0.60.4-Linux.deb
(Reading database ... 11556 files and directories currently installed.)
Preparing to replace repetier-server 0.60.4 (using Repetier-Server-0.60.4-Linux.deb) ...
Uninstall Repetier-Server
/etc/init.d/RepetierServer: line 42: UID: readonly variable
Unpacking replacement repetier-server ...
Setting up repetier-server (0.60.4) ...
Install Repetier-Server
You may see warnings about groups. These can be ignored.
The user `repetierserver' is already a member of `tty'.
adduser: The group `intserial' does not exist.
adduser: The group `ugpio' does not exist.
/var/lib/dpkg/info/repetier-server.postinst: line 12: /etc/sudoers.d/repetierserver-RepetierInstaller: No such file or directory
dpkg: error processing repetier-server (--install):
subprocess installed post-installation script returned error exit status 1
Errors were encountered while processing:
repetier-server
uname -a:
Linux repetierserver 2.6.32-31-pve #1 SMP Thu Jul 24 06:44:16 CEST 2014 x86_64 GNU/Linux
ldd --version:
ldd (Debian EGLIBC 2.13-38+deb7u8) 2.13
Downloaded Version:
Repetier-Server amd64 0.60.4
Any suggestion?
