change filament go crazy after update to 1.4.8
in Bug Reports
configuration:
raspberry pi 3 + touchscreen 7''
REPETIER-SERVER PRO
REPETIER-SERVER PRO
I updated my raspberry pi from 1.4.4 to 1.4.8 by using the update function.
After the update the option to change filament seemed to go crazy.
I set the loading with 300mm Fast Distance and 50mm slow Distance, with 1.4.4 it worked perfectly,
now it loads about double ... I solved it for the moment by setting 180mm and 30mm
just to not break the printer but actually it loads
about 300mm Fast and 50mm Slow with the values set to 180mm and 30mm
As you see it totals to 350mm which is correct.
What do you get as output if you do? If you have a custom insert script it may add extra gcode not considered by our moves. Actually changed gcode to prevent wrong extrusions as you see by setting mode and E position we thing should have before sending the move now.
Thanks for the help.
