Blank WebUI after upgrade 1.4.6>1.4.7 with french or catalan languages
I have an issue since I made the update from v1.4.6 to v1.4.7.
All that was show in the dev tools console was an error for module RSUser not available:
Uncaught Error: [$injector:modulerr] Failed to instantiate module server due to:
Error: [$injector:modulerr] Failed to instantiate module RSUser due to:
Error: [$injector:nomod] Module 'RSUser' is not available! You either misspelled the module name or forgot to load it. If registering a module ensure that you specify the dependencies as the second argument.
I also add crash of the server process at start with an old error (locale::facet::_S_create_c_locale name not valid) but got it corrected with full RasPi update & reboot (does not seems related with the issue).
After some trials and errors, I finally found out that the issue only appear if the locale is set to either french or catalan when using URL parameter ?lang. All other locales are working as expected.
I spotted the difference in the network tab as lots of requests were appended with different ?lang parameter values and forcing a working one corrected the issue.
Maybe some Angular locale files are missing ?
If you need more details, feel free to ask
Regards,
Nicolas.
Regards,
Nicolas.
