Prusa Mini Filament Unload
After a print is finished and I want to change filament I usually disconnect on the printer and hit unload filament. Then I have to reconnect the printer which is super inconvenient. Is there a more efficient way? If I use the filament unload/load configuration in Repetier I have to retract and extrude multiple times. Super annoying and time consuming.
In script you could e.g add a low move first to insert filament and then the fast move.
