Exlcusion Zone Height
When you add an exclusion zone you can set the x and y size, but it automatically defaults to the full z height.
Is it possible to be able to set the z height for the exclusion. sometimes a support will fail, but the support isn't really 100% needed, the over-hang is still within tolerances. I would like to be able to still print the overhang but not have the left-over strings from the failed support potentially causing more problems.
I know in Prusa, Cura and even Lychee there is a preview slider where you can see layer by layer.
I figure it would be treated similar to a filament/color change at layer x.
You have colors for different extruders as well as different types of moves.
What about a different color for every Nth layer? Something to think about. Would require someone to count the colored Nth lines to ballpark a layer height. Of course, super fine layer heights would get "lost" among lots of layers, but might be still doable.
A possibility that crossed my mind.
Another thing that crossed my mind, not really related to the main topic, but along sort of the same lines. In 3D view you have the transparent top layer. Is there a way to possibly specify a light, medium, or dark shading? Sometimes on a small screen or a resized window sharing other apps on one monitor the transparency can be lost visually. I find that I have to "spin" the view around to get a good angle for the best transparency visibility on some prints.
It IS nice though to have another visual representation of the print progress other than the progress bar, eta and ete.
I know, I'm a pain in the butt, but as a daily end user and not a programmer it can be nice to have input about various things that a dev may not consider at programming time.
And STILL absolutely loving Repetier, the cost was soooo worth it and has made administering multiple printers much much easier for me.
I think Cura automatically labels the objects but I honestly don't remember.
IIRC Prusa Slicer is open source and available on github. You could examine their label code pretty easily.
OctoPrint's method of canceling objects worked very well for me as long as i had the label objects turned on in PrisaSLicer. However, their rescue function was VERY hit or miss. Repetier has been the only one that has consistently let me rescue a print from a power or other failure. I think it has only failed to rescue twice and I think that may have been due to the time it took me to notice the failure, so the bed had cooled too much, and the main object came loose upon resuming the print.
https://www.designcreations.us/Screenshot%202023-02-17%20211229.png
https://www.designcreations.us/Screenshot%202023-02-17%20211217.png
Would there be a way to add diagonal exclusions? Or maybe a rotate or even a freeform selection option.
