Configure PWM pin
I try to configure a PWM pin of raspberry pi 3b+ to control a led light for the printer. In global configuration I added an entry for the GPIO PWM, configured a dtoverlay in /boot/config.txt and entered SVG icons in the GPIO config.
My question, where should the icon appear on the desktop?
  • Icon appears next to the menu entry of the pwm if you have "Show in menu" selected. It appears either in the global menu (gear top bar) or if you selected a printer in the printer hambuger menu instead.
  • OK. I found it. Looked for the icons I defined in the settings. But it's ok. Thank you.
