Print Failing due to "Main process exited, code=killed, status=6/ABRT"
My Printer seems to just disconnect randomly mid-print, causing no error in the repetier web-view, but the server log states:
Jan 17 21:25:33 : RepetierServer.service: Failed with result 'signal'.
changed the usb cable, didnt help
ping-pong mode is enabled
anything i can change to prevent that error?
This is no connection issue directly as the server goes down due to internal error signal.
