Possible to Change the Destination of Log Files
We're seeing if there's a way (not apparent in the UI or documentation) to change the location of where the log files are stored. Preferably we'd like them to be put onto a network drive or a separate miscellaneous drive rather than the OS Drive itself. We're using a Windows installation in case that changes anything. I'm fairly comfortable with modifying the installation to get the desired results.
Thanks.
Thanks.
https://www.repetier-server.com/startup-configuration/
What you want is a extra xml with
An other driver on same computer is ok, network drive is nothing I'd do. It is slower in access and a network failure will break prints.
We're utilizing some internal custom applications for our MES and we're just investigating viability of a particular setup.
Thanks again.
