Support Simplify3d v.5 new remote control
Simplify3d version 5 was just released and it allows printers with Wifi to be controlled remotely.
It would be great if Repetier-Server could be used to be a proxy for printers without Wifi to be controlled from Simplify3d.
Also it should be possible to push the gcodes to RS via Wifi then
![;) ;)](/resources/emoji/wink.png)
For simpify3d there is already a solution a bit hand made as we can not change their sources, see
https://www.repetier-server.com/using-simplify-3d-repetier-server/
Or you use Repetier-Server Monitor to automatically upload saved files.
