Z axis not homing before print start
Hi! Being my first post I apologize if I put it in the wrong category. But since this happens only when slicing with Cura I presume this would be the right place.
My setup is as follows:
Repetier-Host 1.5.4 (x64)
Prusa i3 with Marlin
Cura_SteamEngine 15.01
I use the default startup code (see below). The problem I have is that after homing (G28) there's a G1 Z15 command that lifts the extruder but it's not returned to 0 before the print starts. I.e. it's extruding in mid air. Tried adding a G1 Z0 to the end of the start up but didn't help.
Thank you for reading.
; Default start code
G28 ; Home extruder
G1 Z15 F{Z_TRAVEL_SPEED}
M107 ; Turn off fan
G90 ; Absolute positioning
M82 ; Extruder in absolute mode
{IF_BED}M190 S{BED}
; Activate all used extruder
{IF_EXT0}M104 T0 S{TEMP0}
G92 E0 ; Reset extruder position
; Wait for all used extruders to reach temperature
{IF_EXT0}M109 T0 S{TEMP0}
