no audio at @sound command
What is the correct command type for sending an audible alert to Repeater from the printer controller firmware? I've tried various messages with no luck getting Repetier to sound off. The preferences setting in Repetier is turned ON with a sound selected (played when tested). The documentation says the command is "@sound", but this isn't working for me. Is anyone else using this command and getting it to work?
For the other @sound that doesn't work, I've tried adding extra commands around it and even multiple @sounds like this:
@info Before Sound
@sound
@sound
@info After Sound
I see the info messages, but still no sound goes off.
This is using the latest stable Marlin software with Repetier Host 1.5.4 on Windows.
