Error - Repetier-Server currently not avaliable
A few days ago my instance of rep server running on a Rasp pi stopped & started displaying an error on the web browser URL.
I have tried to troubleshoot the issue with no success , so I decided to just reinstall onto the SD, at first this worked for a few hours & then the same error appeared.
I then tried the SD on another raspberry pi to see if it was a hardware issue, but the same error is still present.
If I connect a monitor to the pi, the splash screens go through fast & then i get a blank screen with no ability to use the command line.
I can connect via SSH , but not sure what to try next.
Any idea what could be causing this ? & how I can try to resolve ?
It seems that Repetier-Server is currently not running. Retrying in 27 seconds.
If it does not restart in a reasonable time, the service might be stopped. You can restart the service in a terminal windows sending the command:
sudo service RepetierServer restart
If it fails to start as a service start it manually. You will see the logging on the terminal and will help you hopefully to identify the problem.
export LC_ALL=C
sudo -u repetierserver /usr/local/Repetier-Server/bin/RepetierServer -c /usr/local/Repetier-Server/etc/RepetierServer.xmlerServer.xml
export LC_ALL=C
that starts server again but you will see all error messages in console running ssh. That hopefully shows until which stage it can start and what is than causing the crash. A typical reason is a bad file in /var/lib/Reepetier-Server/database folder. If you see the last line probably a starting xyz message it is likely that the config file needed for this is defect. You can try renaming the file in database and restart. It will be recreated (with empty default content). If it starts that was the defect file and you loos what was stored in that, e.g. ig it was user.sql you loose user list. You can also just rename database fodler to test if it is any file in that and copy it back later to test for more details.
