That's bad. Here delete is really delete, so if you have no backup there is no official way. Depending on os you might be able to recover deleted files, but you never can say which are not corrupted be reusing same disk storage for other files and it is a complicated process. Main file you might want to recover is the xml file in config folder. Thsi contains settings and custome g-codes. With some luck you find a .bak file there, but I think we delete that as well.
