WLAN connection problem
I have repetier server 1.4.3 installed few days ago with ethernet connection (just to setup system), I am not able to set WLAN in the way that it connects automatically at boot without ethernet cable. I used shell from browser (under global settings) to configure it (/boot/wpa_supplicant-wlan0.conf) changing only ssid and password, but if I reboot without ethernet cable system syays that it is not connected to internet...
  • You can also reboot with ethernet connected and use
    ipconfig
    and
    iwconfig
    to see if it works. Makes it easier to play around.
    That solution bypasses our wifi handling completely. But here some known issues you might run into:
    - Did you set country in case your router uses channels not available everywhere?
    - Does you ssid use non ascii chars? That is always a possible issue if charsets differ.
    - Does password only contain ascii chars, is it correct.
    Also have a look at /var/log/syslog where linux logs the connection attempt. There you see if it was tried at all and why it failed.
    Our startup script copies the /boot variant to the correct destination. Check if it is your version:
    sudo cat /etc/wpa_supplicant/wpa_supplicant.conf
  • Hello,
    1) yes I set country during first configuration and then also when I tried connection with /boot/wpa_supplicant-wlan0.conf as well.
    2) SSID has letters and one single underscore
    3) password has only numbers and letters
    Now I am connected with Ethernet, removed /boot/wpa_supplicant-wlan0.conf and tried wireless connection from repetier panel on browser. Output of requested files:
    sudo cat /etc/wpa_supplicant/wpa_supplicant.conf -->   ctrl_interface=DIR=/var/run/wpa_supplicant GROUP=netdev        update_config=1
     /var/log/syslog (during attempt of wireless connection) -->
  • Nov 29 09:40:04 RepetierServer systemd[1]: systemd-timedated.service: Succeeded.        Nov 29 09:40:05 RepetierServer dbus-daemon[318]: [system] Activating via systemd: service name='org.freedesktop.timedate1' unit='dbus-org.freedesktop.timedate1.service' requested by ':1.45' (uid=0 pid=2314 comm="timedatectl ")        Nov 29 09:40:05 RepetierServer systemd[1]: Starting Time & Date Service...        Nov 29 09:40:05 RepetierServer dbus-daemon[318]: [system] Successfully activated service 'org.freedesktop.timedate1'        Nov 29 09:40:05 RepetierServer systemd[1]: Started Time & Date Service.        Nov 29 09:40:06 RepetierServer dhcpcd[2347]: sending signal HUP to pid 389        Nov 29 09:40:06 RepetierServer dhcpcd[389]: received SIGHUP, rebinding        Nov 29 09:40:06 RepetierServer dhcpcd[389]: eth0: confile file changed, expiring leases        Nov 29 09:40:06 RepetierServer dhcpcd[389]: eth0: deleting address fda7:19d3:bb50:4da6:e65f:1ff:fea5:64df/64        Nov 29 09:40:06 RepetierServer avahi-daemon[313]: Withdrawing address record for fda7:19d3:bb50:4da6:e65f:1ff:fea5:64df on eth0.        Nov 29 09:40:06 RepetierServer avahi-daemon[313]: Leaving mDNS multicast group on interface eth0.IPv6 with address fda7:19d3:bb50:4da6:e65f:1ff:fea5:64df.                                             Nov 29 09:40:06 RepetierServer avahi-daemon[313]: Joining mDNS multicast group on interface eth0.IPv6 with address fe80::e65f:1ff:fea5:64df.                                                           Nov 29 09:40:06 RepetierServer avahi-daemon[313]: Registering new address record for fe80::e65f:1ff:fea5:64df on eth0.*.        Nov 29 09:40:06 RepetierServer dhcpcd[389]: eth0: deleting route to fda7:19d3:bb50:4da6::/64        Nov 29 09:40:06 RepetierServer wpa_supplicant[547]: wlan0: CTRL-EVENT-DISCONNECTED bssid=40:b0:76:a7:0d:40 reason=3 locally_generated=1        Nov 29 09:40:06 RepetierServer wpa_supplicant[547]: wlan0: CTRL-EVENT-REGDOM-CHANGE init=CORE type=WORLD        Nov 29 09:40:06 RepetierServer dhcpcd[389]: eth0: deleting address fe80::e65f:1ff:fea5:64df        Nov 29 09:40:06 RepetierServer wpa_supplicant[547]: wlan0: CTRL-EVENT-REGDOM-CHANGE init=USER type=COUNTRY alpha2=IT        Nov 29 09:40:06 RepetierServer avahi-daemon[313]: Withdrawing address record for fe80::e65f:1ff:fea5:64df on eth0.        Nov 29 09:40:06 RepetierServer avahi-daemon[313]: Leaving mDNS multicast group on interface eth0.IPv6 with address fe80::e65f:1ff:fea5:64df.                                                           Nov 29 09:40:06 RepetierServer avahi-daemon[313]: Interface eth0.IPv6 no longer relevant for mDNS.        Nov 29 09:40:06 RepetierServer dhcpcd[389]: eth0: deleting route to 192.168.2.0/24        Nov 29 09:40:06 RepetierServer avahi-daemon[313]: Withdrawing address record for 192.168.2.73 on eth0.        Nov 29 09:40:06 RepetierServer dhcpcd[389]: eth0: deleting default route via 192.168.2.1        Nov 29 09:40:06 RepetierServer avahi-daemon[313]: Leaving mDNS multicast group on interface eth0.IPv4 with address 192.168.2.73.        Nov 29 09:40:06 RepetierServer avahi-daemon[313]: Interface eth0.IPv4 no longer relevant for mDNS.        Nov 29 09:40:07 RepetierServer dhcpcd[389]: eth0: IAID 01:a5:64:df        Nov 29 09:40:07 RepetierServer dhcpcd[389]: eth0: adding address fe80::e65f:1ff:fea5:64df        Nov 29 09:40:07 RepetierServer avahi-daemon[313]: Joining mDNS multicast group on interface eth0.IPv6 with address fe80::e65f:1ff:fea5:64df.                                                           Nov 29 09:40:07 RepetierServer avahi-daemon[313]: New relevant interface eth0.IPv6 for mDNS.        Nov 29 09:40:07 RepetierServer avahi-daemon[313]: Registering new address record for fe80::e65f:1ff:fea5:64df on eth0.*.        Nov 29 09:40:07 RepetierServer dhcpcd[389]: wlan0: confile file changed, expiring leases        Nov 29 09:40:07 RepetierServer dhcpcd[389]: wlan0: deleting address fda7:19d3:bb50:4da6:e65f:1ff:fea5:64e0/64        Nov 29 09:40:07 RepetierServer avahi-daemon[313]: Withdrawing address record for fda7:19d3:bb50:4da6:e65f:1ff:fea5:64e0 on wlan0.        Nov 29 09:40:07 RepetierServer avahi-daemon[313]: Leaving mDNS multicast group on interface wlan0.IPv6 with address fda7:19d3:bb50:4da6:e65f:1ff:fea5:64e0.                                            Nov 29 09:40:07 RepetierServer dhcpcd[389]: wlan0: deleting route to fda7:19d3:bb50:4da6::/64        Nov 29 09:40:07 RepetierServer avahi-daemon[313]: Joining mDNS multicast group on interface wlan0.IPv6 with address fe80::e65f:1ff:fea5:64e0.                                                          Nov 29 09:40:07 RepetierServer avahi-daemon[313]: Registering new address record for fe80::e65f:1ff:fea5:64e0 on wlan0.*.        Nov 29 09:40:07 RepetierServer dhcpcd[389]: wlan0: deleting address fe80::e65f:1ff:fea5:64e0        Nov 29 09:40:07 RepetierServer avahi-daemon[313]: Withdrawing address record for fe80::e65f:1ff:fea5:64e0 on wlan0.        Nov 29 09:40:07 RepetierServer avahi-daemon[313]: Leaving mDNS multicast group on interface wlan0.IPv6 with address fe80::e65f:1ff:fea5:64e0.                                                          Nov 29 09:40:07 RepetierServer avahi-daemon[313]: Interface wlan0.IPv6 no longer relevant for mDNS.        Nov 29 09:40:07 RepetierServer avahi-daemon[313]: Withdrawing address record for 192.168.2.74 on wlan0.        Nov 29 09:40:07 RepetierServer avahi-daemon[313]: Leaving mDNS multicast group on interface wlan0.IPv4 with address 192.168.2.74.        Nov 29 09:40:07 RepetierServer avahi-daemon[313]: Interface wlan0.IPv4 no longer relevant for mDNS.        Nov 29 09:40:07 RepetierServer dhcpcd[389]: wlan0: deleting route to 192.168.2.0/24        Nov 29 09:40:07 RepetierServer dhcpcd[389]: wlan0: deleting default route via 192.168.2.1        Nov 29 09:40:07 RepetierServer avahi-daemon[313]: Got SIGHUP, reloading.        Nov 29 09:40:07 RepetierServer avahi-daemon[313]: No service file found in /etc/avahi/services.        Nov 29 09:40:07 RepetierServer dhcpcd[389]: wlan0: IAID 01:a5:64:e0        Nov 29 09:40:07 RepetierServer dhcpcd[389]: wlan0: adding address fe80::e65f:1ff:fea5:64e0
  • Nov 29 09:40:07 RepetierServer avahi-daemon[313]: Joining mDNS multicast group on interface wlan0.IPv6 with address fe80::e65f:1ff:fea5:64e0.                                                          Nov 29 09:40:07 RepetierServer avahi-daemon[313]: New relevant interface wlan0.IPv6 for mDNS.        Nov 29 09:40:07 RepetierServer avahi-daemon[313]: Registering new address record for fe80::e65f:1ff:fea5:64e0 on wlan0.*.        Nov 29 09:40:07 RepetierServer dhcpcd[389]: eth0: soliciting an IPv6 router        Nov 29 09:40:07 RepetierServer dhcpcd[389]: wlan0: carrier lost        Nov 29 09:40:07 RepetierServer dhcpcd[389]: wlan0: deleting address fe80::e65f:1ff:fea5:64e0        Nov 29 09:40:07 RepetierServer avahi-daemon[313]: Withdrawing address record for fe80::e65f:1ff:fea5:64e0 on wlan0.        Nov 29 09:40:07 RepetierServer avahi-daemon[313]: Leaving mDNS multicast group on interface wlan0.IPv6 with address fe80::e65f:1ff:fea5:64e0.                                                          Nov 29 09:40:07 RepetierServer avahi-daemon[313]: Interface wlan0.IPv6 no longer relevant for mDNS.        Nov 29 09:40:07 RepetierServer dhcpcd[389]: eth0: rebinding lease of 192.168.2.73        Nov 29 09:40:07 RepetierServer dhcpcd[389]: eth0: probing address 192.168.2.73/24        Nov 29 09:40:08 RepetierServer ntpd[602]: Deleting interface #11 wlan0, fe80::e65f:1ff:fea5:64e0%3#123, interface stats: received=0, sent=0, dropped=0, active_time=256 secs                           Nov 29 09:40:08 RepetierServer ntpd[602]: Deleting interface #12 wlan0, 192.168.2.74#123, interface stats: received=0, sent=0, dropped=0, active_time=253 secs                                         Nov 29 09:40:08 RepetierServer ntpd[602]: Deleting interface #15 eth0, 192.168.2.73#123, interface stats: received=126, sent=127, dropped=0, active_time=250 secs                                      Nov 29 09:40:08 RepetierServer ntpd[602]: 212.6.50.243 local addr 192.168.2.73 -> <null>        Nov 29 09:40:08 RepetierServer ntpd[602]: 212.45.144.88 local addr 192.168.2.73 -> <null>        Nov 29 09:40:08 RepetierServer ntpd[602]: 85.199.214.99 local addr 192.168.2.73 -> <null>        Nov 29 09:40:08 RepetierServer ntpd[602]: 80.88.90.14 local addr 192.168.2.73 -> <null>        Nov 29 09:40:08 RepetierServer ntpd[602]: 37.247.53.178 local addr 192.168.2.73 -> <null>        Nov 29 09:40:08 RepetierServer ntpd[602]: 162.159.200.123 local addr 192.168.2.73 -> <null>        Nov 29 09:40:08 RepetierServer ntpd[602]: 93.94.88.50 local addr 192.168.2.73 -> <null>        Nov 29 09:40:08 RepetierServer ntpd[602]: 80.211.178.99 local addr 192.168.2.73 -> <null>        Nov 29 09:40:08 RepetierServer ntpd[602]: 135.125.165.132 local addr 192.168.2.73 -> <null>        Nov 29 09:40:08 RepetierServer ntpd[602]: 162.159.200.1 local addr 192.168.2.73 -> <null>        Nov 29 09:40:08 RepetierServer ntpd[602]: 185.19.184.35 local addr 192.168.2.73 -> <null>        Nov 29 09:40:08 RepetierServer ntpd[602]: 31.14.133.122 local addr 192.168.2.73 -> <null>        Nov 29 09:40:08 RepetierServer ntpd[602]: Deleting interface #16 eth0, fda7:19d3:bb50:4da6:e65f:1ff:fea5:64df#123, interface stats: received=0, sent=0, dropped=0, active_time=250 secs                Nov 29 09:40:08 RepetierServer ntpd[602]: Deleting interface #19 wlan0, fda7:19d3:bb50:4da6:e65f:1ff:fea5:64e0#123, interface stats: received=0, sent=0, dropped=0, active_time=245 secs               Nov 29 09:40:09 RepetierServer wpa_supplicant[547]: wlan0: Trying to associate with SSID 'Asus_Network'        Nov 29 09:40:12 RepetierServer wpa_supplicant[547]: wlan0: Associated with 40:b0:76:a7:0d:40        Nov 29 09:40:12 RepetierServer wpa_supplicant[547]: wlan0: CTRL-EVENT-CONNECTED - Connection to 40:b0:76:a7:0d:40 completed [id=0 id_str=]                                                             Nov 29 09:40:12 RepetierServer wpa_supplicant[547]: wlan0: CTRL-EVENT-SUBNET-STATUS-UPDATE status=0        Nov 29 09:40:12 RepetierServer dhcpcd[389]: wlan0: carrier acquired        Nov 29 09:40:12 RepetierServer dhcpcd[389]: wlan0: IAID 01:a5:64:e0        Nov 29 09:40:12 RepetierServer dhcpcd[389]: wlan0: adding address fe80::e65f:1ff:fea5:64e0        Nov 29 09:40:12 RepetierServer avahi-daemon[313]: Joining mDNS multicast group on interface wlan0.IPv6 with address fe80::e65f:1ff:fea5:64e0.                                                          Nov 29 09:40:12 RepetierServer avahi-daemon[313]: New relevant interface wlan0.IPv6 for mDNS.        Nov 29 09:40:12 RepetierServer avahi-daemon[313]: Registering new address record for fe80::e65f:1ff:fea5:64e0 on wlan0.*.        Nov 29 09:40:12 RepetierServer dhcpcd[389]: wlan0: soliciting an IPv6 router        Nov 29 09:40:12 RepetierServer dhcpcd[389]: wlan0: rebinding lease of 192.168.2.74        Nov 29 09:40:13 RepetierServer dhcpcd[389]: eth0: leased 192.168.2.73 for 86400 seconds        Nov 29 09:40:13 RepetierServer avahi-daemon[313]: Joining mDNS multicast group on interface eth0.IPv4 with address 192.168.2.73.        Nov 29 09:40:13 RepetierServer dhcpcd[389]: eth0: adding route to 192.168.2.0/24        Nov 29 09:40:13 RepetierServer avahi-daemon[313]: New relevant interface eth0.IPv4 for mDNS.        Nov 29 09:40:13 RepetierServer avahi-daemon[313]: Registering new address record for 192.168.2.73 on eth0.IPv4.        Nov 29 09:40:13 RepetierServer dhcpcd[389]: eth0: adding default route via 192.168.2.1        Nov 29 09:40:13 RepetierServer avahi-daemon[313]: Got SIGHUP, reloading.        Nov 29 09:40:13 RepetierServer avahi-daemon[313]: No service file found in /etc/avahi/services.        Nov 29 09:40:14 RepetierServer ntpd[602]: Listen normally on 20 eth0 192.168.2.73:123        Nov 29 09:40:14 RepetierServer ntpd[602]: bind(25) AF_INET6 fe80::e65f:1ff:fea5:64e0%3#123 flags 0x11 failed: Cannot assign requested address                                                          Nov 29 09:40:14 RepetierServer ntpd[602]: unable to create socket on wlan0 (21) for fe80::e65f:1ff:fea5:64e0%3#123        Nov 29 09:40:14 RepetierServer ntpd[602]: failed to init interface for address fe80::e65f:1ff:fea5:64e0%3        Nov 29 09:40:14 RepetierServer ntpd[602]: new interface(s) found: waking up resolver        Nov 29 09:40:17 RepetierServer dhcpcd[389]: wlan0: probing address 192.168.2.74/24        Nov 29 09:40:17 RepetierServer dhcpcd[389]: eth0: Router Advertisement from fe80::18b0:be11:33e4:f4c1        Nov 29 09:40:17 RepetierServer dhcpcd[389]: eth0: adding address fda7:19d3:bb50:4da6:e65f:1ff:fea5:64df/64        Nov 29 09:40:17 RepetierServer avahi-daemon[313]: Leaving mDNS multicast group on interface eth0.IPv6 with address fe80::e65f:1ff:fea5:64df.                                                           Nov 29 09:40:17 RepetierServer avahi-daemon[313]: Joining mDNS multicast group on interface eth0.IPv6 with address fda7:19d3:bb50:4da6:e65f:1ff:fea5:64df.                                             Nov 29 09:40:17 RepetierServer avahi-daemon[313]: Registering new address record for fda7:19d3:bb50:4da6:e65f:1ff:fea5:64df on eth0.*.        Nov 29 09:40:17 RepetierServer dhcpcd[389]: eth0: adding route to fda7:19d3:bb50:4da6::/64        Nov 29 09:40:17 RepetierServer avahi-daemon[313]: Withdrawing address record for fe80::e65f:1ff:fea5:64df on eth0.        Nov 29 09:40:18 RepetierServer ntpd[602]: bind(25) AF_INET6 fda7:19d3:bb50:4da6:e65f:1ff:fea5:64df#123 flags 0x11 failed: Cannot assign requested address                                              Nov 29 09:40:18 RepetierServer ntpd[602]: unable to create socket on eth0 (22) for fda7:19d3:bb50:4da6:e65f:1ff:fea5:64df#123        Nov 29 09:40:18 RepetierServer ntpd[602]: failed to init interface for address fda7:19d3:bb50:4da6:e65f:1ff:fea5:64df        Nov 29 09:40:18 RepetierServer ntpd[602]: bind(25) AF_INET6 fe80::e65f:1ff:fea5:64e0%3#123 flags 0x11 failed: Cannot assign requested address                                                          Nov 29 09:40:18 RepetierServer ntpd[602]: unable to create socket on wlan0 (23) for fe80::e65f:1ff:fea5:64e0%3#123        Nov 29 09:40:18 RepetierServer ntpd[602]: failed to init interface for address fe80::e65f:1ff:fea5:64e0%3        Nov 29 09:40:22 RepetierServer dhcpcd[389]: wlan0: leased 192.168.2.74 for 86400 seconds        Nov 29 09:40:22 RepetierServer avahi-daemon[313]: Joining mDNS multicast group on interface wlan0.IPv4 with address 192.168.2.74.        Nov 29 09:40:22 RepetierServer dhcpcd[389]: wlan0: adding route to 192.168.2.0/24        Nov 29 09:40:22 RepetierServer dhcpcd[389]: wlan0: adding default route via 192.168.2.1        Nov 29 09:40:22 RepetierServer avahi-daemon[313]: New relevant interface wlan0.IPv4 for mDNS.        Nov 29 09:40:22 RepetierServer avahi-daemon[313]: Registering new address record for 192.168.2.74 on wlan0.IPv4.        Nov 29 09:40:23 RepetierServer dhcpcd[389]: wlan0: Router Advertisement from fe80::18b0:be11:33e4:f4c1        Nov 29 09:40:23 RepetierServer dhcpcd[389]: wlan0: adding address fda7:19d3:bb50:4da6:e65f:1ff:fea5:64e0/64        Nov 29 09:40:23 RepetierServer avahi-daemon[313]: Leaving mDNS multicast group on interface wlan0.IPv6 with address fe80::e65f:1ff:fea5:64e0.                                                          Nov 29 09:40:23 RepetierServer avahi-daemon[313]: Joining mDNS multicast group on interface wlan0.IPv6 with address fda7:19d3:bb50:4da6:e65f:1ff:fea5:64e0.                                            Nov 29 09:40:23 RepetierServer avahi-daemon[313]: Registering new address record for fda7:19d3:bb50:4da6:e65f:1ff:fea5:64e0 on wlan0.*.        Nov 29 09:40:23 RepetierServer avahi-daemon[313]: Withdrawing address record for fe80::e65f:1ff:fea5:64e0 on wlan0.        Nov 29 09:40:23 RepetierServer dhcpcd[389]: wlan0: adding route to fda7:19d3:bb50:4da6::/64        Nov 29 09:40:24 RepetierServer ntpd[602]: Listen normally on 24 wlan0 192.168.2.74:123        Nov 29 09:40:24 RepetierServer ntpd[602]: bind(26) AF_INET6 fda7:19d3:bb50:4da6:e65f:1ff:fea5:64df#123 flags 0x11 failed: Cannot assign requested address                                              Nov 29 09:40:24 RepetierServer ntpd[602]: unable to create socket on eth0 (25) for fda7:19d3:bb50:4da6:e65f:1ff:fea5:64df#123        Nov 29 09:40:24 RepetierServer ntpd[602]: failed to init interface for address fda7:19d3:bb50:4da6:e65f:1ff:fea5:64df        Nov 29 09:40:24 RepetierServer ntpd[602]: bind(26) AF_INET6 fda7:19d3:bb50:4da6:e65f:1ff:fea5:64e0#123 flags 0x11 failed: Cannot assign requested address                                              Nov 29 09:40:24 RepetierServer ntpd[602]: unable to create socket on wlan0 (26) for fda7:19d3:bb50:4da6:e65f:1ff:fea5:64e0#123        Nov 29 09:40:24 RepetierServer ntpd[602]: failed to init interface for address fda7:19d3:bb50:4da6:e65f:1ff:fea5:64e0        Nov 29 09:40:24 RepetierServer ntpd[602]: Listen normally on 27 wlan0 [fe80::e65f:1ff:fea5:64e0%3]:123        Nov 29 09:40:24 RepetierServer ntpd[602]: new interface(s) found: waking up resolver        Nov 29 09:40:26 RepetierServer ntpd[602]: bind(27) AF_INET6 fda7:19d3:bb50:4da6:e65f:1ff:fea5:64df#123 flags 0x11 failed: Cannot assign requested address                                              Nov 29 09:40:26 RepetierServer ntpd[602]: unable to create socket on eth0 (28) for fda7:19d3:bb50:4da6:e65f:1ff:fea5:64df#123        Nov 29 09:40:26 RepetierServer ntpd[602]: failed to init interface for address fda7:19d3:bb50:4da6:e65f:1ff:fea5:64df        Nov 29 09:40:26 RepetierServer ntpd[602]: bind(27) AF_INET6 fda7:19d3:bb50:4da6:e65f:1ff:fea5:64e0#123 flags 0x11 failed: Cannot assign requested address                                              Nov 29 09:40:26 RepetierServer ntpd[602]: unable to create socket on wlan0 (29) for fda7:19d3:bb50:4da6:e65f:1ff:fea5:64e0#123        Nov 29 09:40:26 RepetierServer ntpd[602]: failed to init interface for address fda7:19d3:bb50:4da6:e65f:1ff:fea5:64e0        Nov 29 09:40:30 RepetierServer ntpd[602]: Listen normally on 30 eth0 [fda7:19d3:bb50:4da6:e65f:1ff:fea5:64df]:123        Nov 29 09:40:30 RepetierServer ntpd[602]: bind(28) AF_INET6 fda7:19d3:bb50:4da6:e65f:1ff:fea5:64e0#123 flags 0x11 failed: Cannot assign requested address                                              Nov 29 09:40:30 RepetierServer ntpd[602]: unable to create socket on wlan0 (31) for fda7:19d3:bb50:4da6:e65f:1ff:fea5:64e0#123        Nov 29 09:40:30 RepetierServer ntpd[602]: failed to init interface for address fda7:19d3:bb50:4da6:e65f:1ff:fea5:64e0        Nov 29 09:40:30 RepetierServer ntpd[602]: new interface(s) found: waking up resolver        Nov 29 09:40:32 RepetierServer ntpd[602]: bind(28) AF_INET6 fda7:19d3:bb50:4da6:e65f:1ff:fea5:64e0#123 flags 0x11 failed: Cannot assign requested address                                              Nov 29 09:40:32 RepetierServer ntpd[602]: unable to create socket on wlan0 (32) for fda7:19d3:bb50:4da6:e65f:1ff:fea5:64e0#123        Nov 29 09:40:32 RepetierServer ntpd[602]: failed to init interface for address fda7:19d3:bb50:4da6:e65f:1ff:fea5:64e0        Nov 29 09:40:35 RepetierServer ntpd[602]: Listen normally on 33 wlan0 [fda7:19d3:bb50:4da6:e65f:1ff:fea5:64e0]:123        Nov 29 09:40:35 RepetierServer ntpd[602]: new interface(s) found: waking up resolver
  • this was my /boot/wpa_supplicant-wlan0.conf:
    # Windows and Mac Users watch out !!!
    # Ensure line encoding uses unix style line endings. Do not use Notepad or Wordpad or Textedit (Mac).
    # We recommend: Notepad++, Visual Studio Code, Atom, SublimeText, BBEdit or any other good text editor.
    # This is a sample config file for your wifi network. Normally you configure wifi
    # through the Repetier-Server wifi dialog. If this is too unstable due to external
    # factors, you can override it by renaming this file into:
    # wpa_supplicant-wlan0.conf
    # At boot up our scripts check for the existence and if they differ with the installed
    # version. If they do, we will switch to wifi connection through wpa_supplicant
    # using only this config file. The server will not change wifi setup when running.
    update_config=1
    # 2 char uppercase country code to tell linux which frequency bands to use.
    # Example: EN, US, DE, ES, IT, NL, ...
    country=IT
    network={
        # Activate scan_ssid for hidden SSID to work
        # scan_ssid=1
        # Enter the SSID of your router
        ssid="Asus_Network"
        # Enter the password for your wifi router here
        psk="wxxu1rexjw2ksz0c"
        # Most widely use key management type preselected, others are available
        # default is: WPA-PSK WPA-EAP
        # key_mgmt=WPA-PSK
        # You can add other config options. See:
  • Extracting the ipv4 messages for wlan0 I get
    so from this it seems you have a connection and it got ip 192.168.2.74 over wifi. At least in the shown log part I did not see that it stopped.
    So solution seems to work. Happened anythign after connecting? It might take a minute or so to see it in web interface as connected.
    Tip in case there came more - filter syslog for wlan0 messages.
    tail -2000 /var/log/syslog | grep wlan0
    should filte rlast 2000 lines containing wlan0 reducing spam to read. If it seems to miss something like you see it is removing adress but no reason for it check the log at that time above the message. Then you see why it disconnects. But initial connect seems to be working.
