History with bugs in calendar
In the last months, my printer presented a problem in its history. Printing hours and number of printings have been registered in the wrong months, example: all I have printed in October is condensed in the month of September. I checked my network connection and everything seems fine. Anyone knows how I can fix this? If there is some method to ajust the months calendar history correctly?
Note that the fact that you can see pi in your local network does not automatically mean it has also internet access. That is normally the case, but if you have some router firewall active you could prevent it from reaching timeserver port in internet or block all internet traffic. A internet timeserver is used to set time after a restart of the pi. If you login via ssh or in gener settings->terminal you can see and change the date with the "date" command.
