Slic3r Plugin Problems.
Alright, so recently I update RepetierHost to the latest version, being V2.2.4. I've gone through this process a couple of times, and never ran into to many issues.
So, thinking that this is going to be like every other time I've ran through the set up process, I select the appropriate plugins for the Slicer of my chose, being Slic3r, and.... Nothing
For some reason, every time I try to use it, I keep getting the same error message of
<Slic3r> Assembly . '/home/pacst3r1/Downloads/RepetierHost/plugins/SlicerSlic3r/SlicerSlic3r.dll' doesn't have an entry point.
I tried with SlicerSlic3rPE, and got the same message, with the appropriate differences. I tried deleting and re-installing Slic3r, ran through the set up again, same results. I've been at this for over a week now, and I've tried everything I can think of.
I'm the OS I'm using is Ubuntu V22.04.1 LTS, if that's need.
Try running it through netfabb.
I've had similar issues with STLs that have minor artifacts...
Edit: at least this will tell us if it really is your slic3r or if it was something with the file.
