No Longer able to Setup Repetier Via HOST. It forces one to the SERVER. WHY?
Softwarre Issue:
Pepetier host no longer works , it is forced to go to server? why was this changed?
Working from Servers (CLOUD) is never private:
Working from Server means files you work with could be saved at the Server end and they are no longer private.
The server knows everything you slice and print.
While this may not be a concern for some people that simply print for fun, it is for others that design products from scratch and want to maintain thier CAD STL files private.
Am I correct?
Can someone shed some insight into this and if it is possible to get back to operating the software offline via host?.
Thank You.
Am I correct?
Thank You.
WHat me wonders mor eis why host suddenly should not work. We haven't changed it. What is your issue? Does it not start any more? If you installed and configured Repetier-Server on your pc the server will block com port if it is configured for that printer. You then need to either disable the printer in server or in host select the Repetier-Server Connector to print via server.
