External Access
Hey, i want to access the Repetier Server Webinterface, when i am not at home.
I do have a VPN, but makes some Problemes on my iPad.
So i want to have a alternative way, to access the Dashboard.
Is it possible, to access it with Cloudflared Tunnel?
Would you recommend me, to do is with Cloudflared?
And what should i do, if i want to have external Access? I mean security things.
Best Regards
And sorry for my Bad English
Best Regards
https://www.repetier-server.com/knowledgebase/access-server-from-internet/
lists possible solutions. ngrok is probably similar to cloudflare tunnel. VPN is normally the best since you have secure access without making it accible from outside in general. Most important is to add users so in case it is visible for others, they can not use it without finding your password.
