Prusa Mini Pause Y Axis Layer Shift
Hi all, I've been running Repetier Server on our farm for a few years now and its been flawless for our usage, up until recently where we found a really odd issue.
We stop/pause our prints to drop magnets in, and have done so using the ;@pause command (inserted via Prusa Slicer) - which has never let us down up until now - where we are using it with the Prusa Mini+.
Essentially what happens is that the pause command gets actioned, the printer parks and then recommences as would be expected - but there is a significant Y-axis layer shift of about 1.5mm, this is replicable every time on any file - the layer shift is exactly the same.
Printing without the pause renders the file perfectly. Using an M601 in Prusa Slicer as opposed to the ;@pause does exactly the same thing.
Any ideas? I am half convinced this is something I am missing in the printer setup, but am probably confused by the fact that the MK3's work flawlessly with the same commands.
Not strange. Our script "Run on pause" is independent. If you set X180 insted of X0 it would also go to right side with our pause.
