Debugging Firmware Stops
My Lowrider2 CNC is stopping running some gcode. Repetier-Server says the Marlin firmware sent a Stop. What capabilities might Repetier-Server have for debugging a firmware Stop? So far, I have been able to successfully run 3 operations (Drill, 2D Pocket, Bore). The 4th, 2D Contour, made 2 circuits around the piece before stopping, so I don't believe it was a negative or out-of-bounds error. Thank you.
