Can't splice for dual nozzle print
I believe I have my settings right. I have a different nozzle selected for support than for the object but when I splice I end up with one piece being printed from the assigned support nozzle. Any ideas
Actually the 2 color mode in cura is a bit hard and unexpected. You should better start using prusa slicer for such things - there this stuff works much better.
Anyhow, just checked it and could make support using extruder 2 with no problems. Selected wipe tower and Support Extruder 2. On right side I selected support anywhere and support was different material.
Important: After changes you must safe settings first and on right side select the setting you safed or you might just be slicing with different settings then what you think you are using.
