Printer deactivated
My printer is hard to get activated again after things like firmware update, reset the printer using the reset button on the printer or using emergency stop. The printer resets at every event but it just shows as deactivated after these events. I have to select "Activate" from the web gui several times before it turns green. Every time the printer resets. Once it goes white -> yellow I know that the activation will work. Most of the times it's red-> white and deactivated. Is this a bug or something wrong with my setup?
Raspberry Pi 2, image V6, good power supply to both printer and Pi.
Screen recording here:
  • That never happened to me. In fact it should not be possible at all. When you activate it shoudl stay active - maybe getting red after yellow but never go back to inactive. Need to check how that could be possible.
