MPX3 board + DMS DP5 printer
Hi, I use MPX3 board and have this issues:
- after using dev version and choosing MPX board, heatbed do not work. When I switch back to 0.9.2.9 it works
- after autoleveling, which works perfect, I cannot print, as head is on new level, cca 3mm above set autolevel (any fw version). Setting slicer or firmware Z correction does not work.
Thanks for any advice.
«13
  • Thanks. I found a mistake by copying code from marlin from that board it did not adjust to correct naming scheme, Please try the updated version for heaters.
    Regarding autolevel you z probe height seems to be off 3mm resulting in wrong height calculation.
  • edited April 15
    Thanks a lot, I will try dev version toady. Please, can you recommend the right height calculation method? I probably misunderstood. Thanks a lot.
  • See
    it also explains how to do it with the lcd in dev version.
  • edited April 15
    I used set it up this way - go manually down to cca 0.1 (thin paper), then trigger the probe and tighten probe screws. Then tune up Z-probe height value until the Z is OK (gap 0.1 mm). It worked with old printer, now prints cca 3mm above bed.
    When I use the repetier described method, the extruder push the bed little down when homing Z. But it prints correctly - unfortunately only first layer, then it "hops" another cca 3mm above 1st layer and print is bad.
    I use slic3r, no Z offset.
    This is my second printer, the first used  MKS Base V1.5 board, the same config.h, no problems.
    MPX.3 seems to behave different way...
    HW: MPX.3 board, SN04-N probe, Steppers Busheng 17HD40005-22B
    Configuration.h - here
    Thanks for any advice..
  • Your calibration is most likely missing correctness or is incomplete. When you are at 0.1mm nozzle distance the probe should already have triggered. You need to do it the other way around. Go down until it triggers and get z position. Then go down till nozzl eis on bed and note z again. The difference is z probe height which you need to use.
  • Will try, thanks!
  • edited April 16
    So this method gives bad results - it is the same as it was - it prints cca 3mm above bed from the beginning... probably I have bad setup somewhere, I am desperate how to find... Do you think I could have bad steppers setup?
    Thanks.
  • Do you have ALWAYS_CHECK_ENDSTOPS 0 ? If you have inductive/ir probe it might prevent coming down if using z hop and maybe some other cases.
    Also do you z max homing or have z probe = z min pin?
  • yes, ALWAYS_CHECK_ENDSTOPS 0
    now I wanna add Z_max, but not homing Z_max
  • You should first test G32 and see if after that G1 Z0 is at z=0. Correct z probe height by difference and try again. Make sure bed coating is set to 0. Then if G32 works try homing z. That should then have correct height. Best try with dev version, which has several fixes regarding z probe = zmin.
  • Thanks, I use DEV version. I will try.
  • It works perfectly, but then, after Z homing, ext0 goes up several milimetres and M114 reports Z = 0 (but it is in fact several milimetres up... thus, it prints in this distance above the bed.
  • I start thinking, that the board has some failure, or I am stupid... :-(
  • G32:
    00:12:39.709 : g32
    00:12:40.260 : Z correction disabled
    00:12:40.260 : Info:Autoleveling disabled
    00:12:51.097 : Z-probe:0.550 X:0.00 Y:0.00
    00:12:52.198 : Z-probe:0.638 X:0.00 Y:60.00
    00:12:53.927 : Z-probe:0.664 X:0.00 Y:120.00
    00:12:56.567 : Z-probe:0.665 X:0.00 Y:180.00
    00:13:00.947 : Z-probe:0.592 X:50.00 Y:0.00
    00:13:02.038 : Z-probe:0.665 X:50.00 Y:60.00
    00:13:04.218 : Z-probe:0.682 X:50.00 Y:120.00
    00:13:06.408 : Z-probe:0.664 X:50.00 Y:180.00
    00:13:10.334 : Z-probe:0.679 X:100.00 Y:0.00
    00:13:11.976 : Z-probe:0.734 X:100.00 Y:60.00
    00:13:14.068 : Z-probe:0.732 X:100.00 Y:120.00
    00:13:15.807 : Z-probe:0.698 X:100.00 Y:180.00
    00:13:20.643 : Z-probe:0.751 X:150.00 Y:0.00
    00:13:22.818 : Z-probe:0.796 X:150.00 Y:60.00
    00:13:25.007 : Z-probe:0.779 X:150.00 Y:120.00
    00:13:26.099 : Z-probe:0.738 X:150.00 Y:180.00
    00:13:26.099 : plane: a = 0.0009 b = 0.0003 c = 0.5959
    00:13:26.100 : Transformation matrix: 1.000000 0.000000 -0.000942 -0.000000 1.000000 -0.000251 0.000942 0.000251 1.000000
    00:13:26.100 : Printer height:255.52
    00:13:26.100 : CurrentZ:0.60 atZ:0.19
    00:13:26.100 : Info:Autoleveling enabled
    00:13:26.100 : X:150.00 Y:180.00 Z:0.782 E:5.1243
    00:16:35.372 : m114 (trigered probe)
    00:16:35.410 : X:150.00 Y:180.00 Z:0.150 E:5.1243
    00:17:49.620 : m114 (touch the bed)
    00:17:49.787 : X:150.00 Y:180.00 Z:0.100 E:5.1243
    Z-probe height = 0.150 - 0.100 = 0.050
    Coating thickness = 0
    Print - 00:35:46.693 : m114
    00:35:47.177 : X:0.00 Y:0.00 Z:0.000 E:4.3676
    Actually 1.9 mm from the bed surface
        MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE.  See the
        along with Repetier-Firmware.  If not, see <http://www.gnu.org/licenses/>.
    #ifndef CONFIGURATION_H
    #define CONFIGURATION_H
       This file is optimized for version 1.0.0dev
       as you expect.
    #define NUM_EXTRUDER 1
    #define MOTHERBOARD 38
    #include "pins.h"
    #undef FAN_BOARD_PIN
    #define FAN_BOARD_PIN -1
    #define BOARD_FAN_SPEED 255
    #define BOARD_FAN_MIN_SPEED 0
    #define FAN_THERMO_PIN -1
    //#define EXTERNALSERIAL  use Arduino serial library instead of build in. Requires more ram, has only 63 byte input buffer.
    //#define COMPAT_PRE1
    #define BLUETOOTH_SERIAL  -1
    #define BLUETOOTH_BAUD  115200
    #define MIXING_EXTRUDER 0
    #define DRIVE_SYSTEM 0
    #define XAXIS_STEPS_PER_MM 80
    #define YAXIS_STEPS_PER_MM 80
    #define ZAXIS_STEPS_PER_MM 1600
    #define PDM_FOR_EXTRUDER 0
    #define PDM_FOR_COOLER 0
    #define KILL_IF_SENSOR_DEFECT 1
    #define RETRACT_ON_PAUSE 2
    #define PAUSE_END_COMMANDS ""
    #define EXT0_X_OFFSET 0
    #define EXT0_Y_OFFSET 0
    #define EXT0_Z_OFFSET 0
    #define EXT0_STEPS_PER_MM 370
    #define EXT0_INVERSE 1
    #define EXT0_ENABLE_ON 0
    #define EXT0_MIRROR_STEPPER 0
    #define EXT0_INVERSE2 0
    #define EXT0_MAX_FEEDRATE 50
    #define EXT0_HEAT_MANAGER 3
    #define EXT0_PREHEAT_TEMP 190
    #define EXT0_WATCHPERIOD 1
    #define EXT0_PID_I 2
    #define EXT0_PID_D 40
    #define EXT0_PID_MAX 255
    #define EXT0_ADVANCE_K 0
    #define EXT0_ADVANCE_L 0
    #define EXT0_JAM_PIN -1
    #define EXT0_JAM_PULLUP 0
    #define FEATURE_RETRACTION 1
    #define AUTORETRACT_ENABLED 0
    #define RETRACTION_LENGTH 3
    #define RETRACTION_SPEED 40
    #define RETRACTION_Z_LIFT 0
    #define FILAMENTCHANGE_Z_ADD  0
    #define JAM_METHOD 1
    #define JAM_STEPS 220
    #define JAM_SLOWDOWN_TO 70
    #define JAM_ERROR_STEPS 500
    #define JAM_MIN_STEPS 10
    #define JAM_ACTION 1
    #define RETRACT_DURING_HEATUP false
    #define PID_CONTROL_RANGE 20
    #define SKIP_M109_IF_WITHIN 2
    #define SCALE_PID_TO_MAX 0
    #define TEMP_HYSTERESIS 0
    #define EXTRUDE_MAXLENGTH 160
    #define GENERIC_THERM_VREF 5
    #define HEATER_PWM_SPEED 0
    #define COOLER_PWM_SPEED 0
    #define HAVE_HEATED_BED 1
    #define SKIP_M190_IF_WITHIN 3
    #define HEATED_BED_PID_PGAIN_OR_DEAD_TIME   196
    #define HEATED_BED_PID_IGAIN   33
    #define MIN_EXTRUDER_TEMP 150
    #define MAXTEMP 275
    // ##                             Laser configuration                                      ##
    automatically disabled.
    #define SUPPORT_LASER 0
    #define LASER_PIN -1
    #define LASER_ON_HIGH 1
    #define LASER_WARMUP_TIME 0
    // ##                              CNC configuration                                       ##
    #define SUPPORT_CNC 0
    #define CNC_WAIT_ON_DISABLE 0
    #define CNC_ENABLE_PIN -1
    #define CNC_ENABLE_WITH 1
    #define CNC_DIRECTION_PIN -1
    #define CNC_DIRECTION_CW 1
    #define ENDSTOP_PULLUP_Z2_MINMAX false
    #define ENDSTOP_PULLUP_X_MAX false
    #define ENDSTOP_PULLUP_Y_MAX false
    #define ENDSTOP_Z_MAX_INVERTING true
    #define DOOR_PIN -1
    #define DOOR_PULLUP 1
    #define DOOR_INVERTING 0
    #define ENDSTOP_X_BACK_MOVE 5
    #define ENDSTOP_Y_BACK_MOVE 5
    #define ENDSTOP_Z_BACK_MOVE 2
    #define MOVE_X_WHEN_HOMED 0
    #define MOVE_Y_WHEN_HOMED 0
    #define MOVE_Z_WHEN_HOMED 0
    #define X_ENABLE_ON 0
    #define Y_ENABLE_ON 0
    #define Z_ENABLE_ON 0
    #define DISABLE_X 0
    #define DISABLE_Y 0
    #define DISABLE_Z 0
    #define DISABLE_E 0
    #define PREVENT_Z_DISABLE_ON_STEPPER_TIMEOUT
    #define INVERT_X_DIR 0
    #define INVERT_Y_DIR 1
    #define INVERT_Z_DIR 0
    #define X_HOME_DIR -1
    #define Y_HOME_DIR -1
    #define Z_HOME_DIR -1
    #define X_MAX_LENGTH 200
    #define Y_MAX_LENGTH 200
    #define Z_MAX_LENGTH 255
    #define X_MIN_POS 0
    #define Y_MIN_POS 0
    #define Z_MIN_POS 0
    #define Z2_MINMAX_PIN -1
    #define DISTORTION_CORRECTION_POINTS 4
    #define DISTORTION_START_DEGRADE 0.3
    #define DISTORTION_XMIN 10
    #define DISTORTION_YMIN 10
    #define DISTORTION_XMAX 150
    #define DISTORTION_YMAX 150
    // ##                           Movement settings                                          ##
    #define EXACT_DELTA_MOVES 1
    // Delta settings
    #define DELTA_HOME_ON_POWER 0
    #define STEPPER_INACTIVE_TIME 600L
    #define MAX_INACTIVE_TIME 0L
    #define MAX_FEEDRATE_X 200
    #define MAX_FEEDRATE_Y 200
    #define MAX_FEEDRATE_Z 2
    #define HOMING_FEEDRATE_X 40
    #define HOMING_FEEDRATE_Y 40
    #define HOMING_FEEDRATE_Z 2
    #define HOMING_ORDER HOME_ORDER_YXZ
    #define ZHOME_PRE_RAISE 0
    #define ZHOME_PRE_RAISE_DISTANCE 0
    #define ZHOME_HEAT_ALL 1
    #define ZHOME_HEAT_HEIGHT 20
    #define ZHOME_X_POS 999999
    #define ZHOME_Y_POS 999999
    #define ENABLE_BACKLASH_COMPENSATION 1
    #define X_BACKLASH 0
    #define Y_BACKLASH 0
    #define Z_BACKLASH 0
    #define RAMP_ACCELERATION 1
    #define STEPPER_HIGH_DELAY 0
    #define DIRECTION_DELAY 0
    #define ALLOW_QUADSTEPPING 1
    #define MAX_JERK 20
    #define MAX_ZJERK 0.4
    #define MOVE_CACHE_LOW 10
    #define DUAL_X_AXIS 0
    #define DUAL_X_RESOLUTION 0
    #define X2_STEP_PIN   ORIG_Z_STEP_PIN
    #define X2_DIR_PIN    ORIG_Z_DIR_PIN
    #define X2_ENABLE_PIN ORIG_Z_ENABLE_PIN
    #define Y2_STEP_PIN   ORIG_E1_STEP_PIN
    #define Y2_DIR_PIN    ORIG_E1_DIR_PIN
    #define Z2_STEP_PIN   ORIG_E1_STEP_PIN
    #define Z2_DIR_PIN    ORIG_E1_DIR_PIN
    #define Z3_STEP_PIN   ORIG_E2_STEP_PIN
    #define Z3_DIR_PIN    ORIG_E2_DIR_PIN
    #define Z4_STEP_PIN   ORIG_E3_STEP_PIN
    #define Z4_DIR_PIN    ORIG_E3_DIR_PIN
    #define USE_ADVANCE 0
    #define BAUDRATE 115200
    #define ENABLE_POWER_ON_STARTUP 0
    #define POWER_INVERTING 0
    #define KILL_METHOD 1
    #define ACK_WITH_LINENUMBER 0
    #define ECHO_ON_EXECUTE 1
    #define EEPROM_MODE 1
    #undef PS_ON_PIN
    #define JSON_OUTPUT 0
    /* ======== Servos =======
    Control the servos with
    M340 P<servoId> S<pulseInUS>   / ServoID = 0..3  pulseInUs = 500..2500
    #define FEATURE_SERVO 0
    #define SERVO0_PIN 11
    #define SERVO1_PIN -1
    #define SERVO2_PIN -1
    #define SERVO3_PIN -1
    #define SERVO0_NEUTRAL_POS  -1
    #define SERVO1_NEUTRAL_POS  -1
    #define SERVO2_NEUTRAL_POS  -1
    #define SERVO3_NEUTRAL_POS  -1
    #define UI_SERVO_CONTROL 0
    #define FAN_KICKSTART_TIME  200
            #define FEATURE_WATCHDOG 1
    #define Z_PROBE_Z_OFFSET 0
    #define UI_BED_COATING 1
    #define FEATURE_Z_PROBE 1
    #define EXTRUDER_IS_Z_PROBE 0
    #define Z_PROBE_BED_DISTANCE 5
    #define Z_PROBE_PULLUP 0
    #define Z_PROBE_ON_HIGH 1
    #define Z_PROBE_X_OFFSET 0
    #define Z_PROBE_Y_OFFSET -7
    #define Z_PROBE_SPEED 2
    #define Z_PROBE_XY_SPEED 100
    #define Z_PROBE_REPETITIONS 1
    #define Z_PROBE_HEIGHT 0.09
    #define FEATURE_AUTOLEVEL 1
    #define Z_PROBE_X1 0
    #define Z_PROBE_Y1 0
    #define Z_PROBE_X2 150
    #define Z_PROBE_Y2 0
    #define Z_PROBE_X3 0
    #define Z_PROBE_Y3 180
    #define BED_LEVELING_METHOD 1
    #define BED_LEVELING_GRID_SIZE 4
    #define BED_MOTOR_1_X 0
    #define BED_MOTOR_1_Y 0
    #define BED_MOTOR_2_X 200
    #define BED_MOTOR_2_Y 0
    #define BED_MOTOR_3_X 100
    #define BED_MOTOR_3_Y 200
    #define FEATURE_AXISCOMP 0
    #define AXISCOMP_TANXY 0
    #define AXISCOMP_TANYZ 0
    #define AXISCOMP_TANXZ 0
    #ifndef SDSUPPORT  // Some boards have sd support on board. These define the values already in pins.h
    #define SDSUPPORT 1
    #undef SDCARDDETECT
    #define SDCARDDETECT -1
    #define SD_RUN_ON_STOP ""
    #define ARC_SUPPORT 0
    #define FEATURE_FAN_CONTROL 1
    #define FEATURE_CONTROLLER 2
    #define ADC_KEYPAD_PIN -1
    #define LANGUAGE_EN_ACTIVE 1
    #define LANGUAGE_DE_ACTIVE 0
    #define LANGUAGE_NL_ACTIVE 0
    #define LANGUAGE_PT_ACTIVE 0
    #define LANGUAGE_IT_ACTIVE 0
    #define LANGUAGE_ES_ACTIVE 0
    #define LANGUAGE_FI_ACTIVE 0
    #define LANGUAGE_SE_ACTIVE 0
    #define LANGUAGE_FR_ACTIVE 0
    #define LANGUAGE_CZ_ACTIVE 1
    #define LANGUAGE_PL_ACTIVE 0
    #define LANGUAGE_TR_ACTIVE 0
    #define UI_PRINTER_NAME "DP5"
    #define UI_PRINTER_COMPANY "DMS"
    #define FEATURE_UI_KEYS 0
    #define UI_ENCODER_SPEED 1
    #define UI_REVERSE_ENCODER 0
    #define UI_KEY_BOUNCETIME 10
    #define UI_KEY_MIN_REPEAT 50
    #define FEATURE_BEEPER 0
    #define CASE_LIGHTS_PIN -1
    #define UI_SET_MIN_HEATED_BED_TEMP  30
    #define UI_SET_MIN_EXTRUDER_TEMP   170
    #define UI_SET_MAX_EXTRUDER_TEMP   260
    #define NUM_MOTOR_DRIVERS 0
  • I can´t find any reason, why it prints 1.9 mm above the surface...
    Thanks for any idea...
  • You have the very special case of max and min z endstop. That seems confusing for the firmware as it takes routines meant for z max homing like computing the z length from distance to top, while neglecting the special problems in that case since #define MOVE_Z_WHEN_HOMED 0 is not good for z max homing but required for z min homing.
    Not sure if it comes from this but it is most likely that there is a connection.
    So please try deactivating z max endstop by setting hardware endstop false.
    Alternatively set homing direction 1 for z and #define MOVE_Z_WHEN_HOMED 2 and z min hardware endstop false.
    See if any of these combinations would work correctly, then we can start finding the firmware code adding the error. Thes eboth cases are used by many users so known to be working and if they work we know settings are correct and any error coming after enabling second endstop is in firmware code.
  • So I set and will test:
    #define ENDSTOP_Z_BACK_ON_HOME 1
    #define ENDSTOP_PULLUP_Z_MAX false
    OK?
    Thanks, Ota
  • No, you mixed the 2 cases.
    Case 1:
    Case 2:
  • Thanks,  so  both cases are equal for autoleveling probe as Z-Min without Z-Max endstop? I am little confused, I cant understand the basic principle...
  • No one is max homing and z probing and case 2 is min homing with z probe and z probing without z max endstop.
    The problem as said might appear from having min and max endstops the same time with min endstop being a z probe in reality.
  • OK, thanks!
  • Now endstops m119: x_min:L y_min:L Z-probe state:H but probe is off... (using case 2)
  • I changed Z_PROBE_ON_HIGH 0 (was 1), G32 OK, but prints still high - its lower, but not on Z :-(
  • If you say G32 ok includes that z height after probing? If not z probe height is wrong and that will always lead to wrong z when homing.
    Which case did you use?
  • I used case 2. I do not understand "includes that z height after probing?"
    19:04:02.066 : m119
    19:04:02.396 : endstops hit: x_min:L y_min:L Z-probe state:L
    19:04:25.842 : g32
    19:04:26.461 : Z correction disabled
    19:04:26.461 : Info:Autoleveling disabled
    19:04:36.207 : Z-probe:10.174 X:0.00 Y:0.00
    19:04:47.146 : Z-probe:10.250 X:0.00 Y:60.00
    19:04:58.087 : Z-probe:10.280 X:0.00 Y:120.00
    19:05:09.017 : Z-probe:10.279 X:0.00 Y:180.00
    19:05:21.048 : Z-probe:10.221 X:50.00 Y:0.00
    19:05:31.997 : Z-probe:10.289 X:50.00 Y:60.00
    19:05:42.926 : Z-probe:10.294 X:50.00 Y:120.00
    19:05:53.866 : Z-probe:10.285 X:50.00 Y:180.00
    19:06:05.897 : Z-probe:10.276 X:100.00 Y:0.00
    19:06:16.827 : Z-probe:10.355 X:100.00 Y:60.00
    19:06:27.875 : Z-probe:10.357 X:100.00 Y:120.00
    19:06:38.804 : Z-probe:10.316 X:100.00 Y:180.00
    19:06:51.385 : Z-probe:10.354 X:150.00 Y:0.00
    19:07:02.320 : Z-probe:10.405 X:150.00 Y:60.00
    19:07:13.259 : Z-probe:10.396 X:150.00 Y:120.00
    19:07:24.196 : Z-probe:10.350 X:150.00 Y:180.00
    19:07:24.197 : plane: a = 0.0009 b = 0.0003 c = 10.2140
    19:07:24.197 : Transformation matrix: 1.000000 0.000000 -0.000892 -0.000000 1.000000 -0.000269 0.000892 0.000269 1.000000
    19:07:24.197 : CurrentZ:10.21 atZ:0.00
    19:07:24.197 : Info:Autoleveling enabled
    19:07:24.197 : X:149.99 Y:180.00 Z:10.396 E:0.0000
    19:07:45.296 : g1 z0
    19:07:58.961 : m114
    19:07:59.742 : X:149.99 Y:180.00 Z:0.000 E:0.0000
    EEPROM:
    z-probe height 0,100  (result of the measurement  z-triggered - z-touchbed)
    coating 0,05
  • Printing adds cca 2.3 mm (from z0)
    G32 again after print
    19:19:52.821 : g32 s2
    19:19:52.914 : Z correction disabled
    19:19:52.915 : Info:Autoleveling disabled
    19:19:55.002 : Z-probe:1.259 X:0.00 Y:0.00
    19:19:56.196 : Z-probe:1.350 X:0.00 Y:60.00
    19:19:58.282 : Z-probe:1.381 X:0.00 Y:120.00
    19:20:00.475 : Z-probe:1.381 X:0.00 Y:180.00
    19:20:03.753 : Z-probe:1.307 X:50.00 Y:0.00
    19:20:05.942 : Z-probe:1.380 X:50.00 Y:60.00
    19:20:08.132 : Z-probe:1.398 X:50.00 Y:120.00
    19:20:09.869 : Z-probe:1.374 X:50.00 Y:180.00
    19:20:13.602 : Z-probe:1.392 X:100.00 Y:0.00
    19:20:14.798 : Z-probe:1.453 X:100.00 Y:60.00
    19:20:16.883 : Z-probe:1.454 X:100.00 Y:120.00
    19:20:19.073 : Z-probe:1.417 X:100.00 Y:180.00
    19:20:22.352 : Z-probe:1.457 X:150.00 Y:0.00
    19:20:24.532 : Z-probe:1.513 X:150.00 Y:60.00
    19:20:26.821 : Z-probe:1.494 X:150.00 Y:120.00
    19:20:28.914 : Z-probe:1.449 X:150.00 Y:180.00
    19:20:28.914 : plane: a = 0.0009 b = 0.0003 c = 1.3086
    19:20:28.914 : Transformation matrix: 1.000000 0.000000 -0.000942 -0.000000 1.000000 -0.000270 0.000942 0.000270 1.000000
    19:20:28.914 : CurrentZ:1.31 atZ:1.00
    19:20:28.914 : Info:Autoleveling enabled
    19:20:30.002 : X:150.00 Y:180.00 Z:1.498 E:0.0000
    it seems to give different data.
  • Data needs context to understand as I do not see what you have in reality.
    1. G32 is it at bottom after G1 Z0?
    2. G32 after print is useless as it removes old z. Better etst is test the important part
    G28
    G1 Z0
    what distance do you have then? That is the only important part.
    Also make sure ALWAYS_CHECK_ENDSTOPS 0 so z probe can hot prevent G1 from moving down.
  • G32, G1 Z0 is Z0 = m114 - 0.00
    Print - + cca 2.3 mm, but m114 says z 0.00
    Printer heats, but when heat is OK, go downs to "Z0" which is not real Z0... (+ 2,...mm).
  • edited April 24
    Interesting is, that in the past, with using the recommended Z calibration, once the first layer was OK - but the other were +2.3 mm... then all the time the Z0 is Z0 + 2.3 mm
