DaVinci Missing Line Detected - Correcting Buffer Useage
I just installed Repetier Hose on my DaVinci 1.0A and I did my first print without issues. Now it keeps telling me there is a missing line detected and correcting buffer usage. Sadly I'm new to this software and a little lost as to what I have typed in wrong.
Here's my G-Code if that helps:
Start G-Code:
M140 S[first_layer_bed_temperature] ; Bed (no wait)
M106 S255 ; Start fan
G90 ; set absolute coordinates
G28 ; home all axis
M190 S[first_layer_bed_temperature] ; Bed (wait)
M104 S[first_layer_temperature] ; Extruder (no wait)
M109 S[first_layer_temperature] ; Extruder (wait)
M117 Start
M117 Cleaning
End G-Code: M117; Done
G92 E0 ; reset extrusion distance
G1 E-3 F600 ; Retract
M104 S0 ; turn off extruder
M140 S0 ; turn off Bed
G90 ; Absolute
G28 X-33 Y-12 ; home x & y
G1 Z150 ; Lower bed
M100 ; Cleaning
  • This is about communication with firmware. Firmware acknowledges which line it just received and if you send line 5 and 6 you should get
    ok 5
    ok 6
    but if you only get
    o 5
    ok 6
    It sees line 6 received and sees it missed line 5 because host did not understand the defect answer. Then you get this message. Enable ACK and commands in log and you will see this in more detail. Perhaps also some other resend errors assuming that both directions get errors.
    You could try different baud rates (115200 and 250000) and different usb cables. Make sure not to cross close to power cables for bed or extruder. Then you might get it nearly error free. A error every now and then is normally no problem, that is why we have all these error checking included.
  • Thank you, I'll try a different cable but from what I gather everything is okay.
