0.80 on Pi B+ ; What image to use?
Hello,
Trying to access http://<ip address>:3344 from a computer located on the same local network than the Raspberry Pi B+, I obtain the error:
"This site can’t be reached
<ip address> refused to connect.
ERR_CONNECTION_REFUSED"
Should I use a different image than the image dedicated to Raspberry Pi?
How to make it work?
Best Regards,
  • Problem resolved:
    Switching back the Raspberry Pi host name to RepetierServer makes it work!
  • That is strange. Server ignores pi host name completely. It has only influence on url if you use it as name.
    BTW: For image you can omit :3344 since we have a reverse proxy installed for it.
