Unable to install 8 on rasp pi 2
Hi! Trying to upgrade from 75.1 to 80 on my pi2 but I get the following output and the server doesnt install
sudo dpkg -i Repetier-Server-0.80.0-Linux.deb
(Reading database ... 112027 files and directories currently installed.)
Preparing to unpack Repetier-Server-0.80.0-Linux.deb ...
Uninstall Repetier-Server
[ ok ] Stopping RepetierServer (via systemctl): RepetierServer.service.
Unpacking repetier-server (0.80.0) over (0.75.1) ...
Setting up repetier-server (0.80.0) ...
Install Repetier-Server
You may see warnings about groups. These can be ignored.
The user `repetierserver' is already a member of `tty'.
adduser: The group `intserial' does not exist.
adduser: The group `ugpio' does not exist.
Created symlink from /etc/systemd/system/multi-user.target.wants/RepetierServer.service to /lib/systemd/system/RepetierServer.service.
Job for RepetierServer.service failed. See 'systemctl status RepetierServer.service' and 'journalctl -xn' for details.
dpkg: error processing package repetier-server (--install):
subprocess installed post-installation script returned error exit status 1
Processing triggers for systemd (215-17+deb8u5) ...
Errors were encountered while processing:
repetier-server
Any suggestiuons?
from systemctl status RepetierServer.service:
● RepetierServer.service - Repetier-Server 3D print server
Loaded: loaded (/lib/systemd/system/RepetierServer.service; enabled)
Active: failed (Result: start-limit) since Thu 2016-10-20 18:03:17 BST; 1s ago
Process: 25897 ExecStart=/usr/local/Repetier-Server/bin/RepetierServer -c /usr/local/Repetier-Server/etc/RepetierServer.xml --daemon (code=killed, signal=ILL)
Process: 25893 ExecStartPre=/bin/chown -R repetierserver /var/lib/Repetier-Server (code=exited, status=0/SUCCESS)
Process: 25889 ExecStartPre=/bin/mkdir -p /var/lib/Repetier-Server (code=exited, status=0/SUCCESS)
There is nothing in the server.log
