I installed repetier-server on my Mac mini, but I think I messed up something. Is there a way that I can uninstall it so I can start over from a fresh slate?
I just wanted to try Repetier-server to see what it is, I'm on a machine that will not be connected to the printer so I want to properly uninstall and revert any modifications the installer did.
But I'm now discovering that there's no automated uninstall process, so I have to do it by hand... I'm not happy having to take time to cleanup
So first, the uninstallLaunchd.sh script is failing because you changed the name of the daemon launcher file from "RepetierServer.plist" to "com.repetier-server.RepetierServer.plist".
And then I discovered that the installer created a User profile. I hope I haven't missed anything else. If so, please tell me. I hate discovering leftover from old apps bloating up my computer. I carry on my OS installation from machine to machine. I never reinstall it, I only update.
And here is the full script to completely remove (I hope) Repetier-server:
Thanks for the hint. Hadn't registered the name change to more confirming.
For next release I have added a script to do a full uninstall (fulluninstall.sh) as you suggested, just with some questions to skip data and security question.
I had this same issue... did all up to this point - used your code to stop the server - but now the USB driver is removed and it will not re-intsall. If you get a notification for this - can you offer a solution?? TIA
The problem is that the firmware on Anet motherboard - does not use a real USB connection.
After some information passed from a forum - I downloaded - "http://www.prolific.com.tw/US/ShowProduct.aspx?p_id=229&pcid=41 " Its a USB - Serial bridge. I rean the application.... when it finished - restarted the computer, opened HOST and check the printer settings. Selected the driver and then set up a print controlled from computer via USB cable... all is well and my world is a better place!!
/usr/local/Repetier-Server
and with
sudo /usr/local/Repetier-Server/bin/uninstallLaunchd.sh
you stop the running daemon. Run this before you delete the installation directory!
Configurations/databases reside in
/Library/Application Support/Repetier-Server/
If you have crashed a database stop daemon and delete databases in storage directory. Then start daemon again
sudo /usr/local/Repetier-Server/bin/installLaunchd.sh
Thanks to all who tried to find a solution.
