[0.75.1] Alternative server (Conectivity) issue
in Bug Reports
My setup: PC -> Alix Board - > Arduino.
Alix Board: Repetier Server
PC: Alternative Server for FFMPEG and model rendering
First day after connecting it everything worked great. Fast rendering, ffmpeg conversion of webcam shoots.
An day after, none of those works anymore. Rendering keeps showing "Rendering" image, Recordings shows Converting all the time.
I have tried to remove and re-insert API, IP of PC witch Alix detect as Repetier-Renderer and Video Converter services.
But still no rendering and ffmpeg conversion.
Server log fine (Alix side) shows following:
2016-05-12 19:45:07: Job created: /var/lib/Repetier-Server/printer/MP20/models/00000016_1x carrello_sotto_netfabb_mm.u
2016-05-12 19:45:07: finish job /var/lib/Repetier-Server/printer/MP20/models/00000016_1x carrello_sotto_netfabb_mm.u
2016-05-12 19:45:07: Uploaded size:8337417
2016-05-12 19:45:07: Updating info for /var/lib/Repetier-Server/printer/MP20/models/00000016_1x carrello_sotto_netfabb_mm.g printer MP20
2016-05-12 19:45:07: line 141
2016-05-12 21:34:20: Client closed connection unexpectedly
2016-05-12 21:44:49: Job created: /var/lib/Repetier-Server/printer/MP20/jobs/00000003_2x laterale_netfabb_mm.u
2016-05-12 21:44:50: finish job /var/lib/Repetier-Server/printer/MP20/jobs/00000003_2x laterale_netfabb_mm.u
2016-05-12 21:44:50: Added timelapse 20160512T214450_2x laterale_netfabb_mm
2016-05-12 22:10:49: Client closed connection unexpectedly
2016-05-12 22:10:51: Client closed connection unexpectedly
2016-05-12 22:36:06: Call of rs:toJsonObject without table
2016-05-12 22:40:19: Call of rs:toJsonObject without table
At PC side, there is no entery for any job from Alix.
Maybe it stops working if I reboot Alternative Server or something like that ?
