Installing 0.75 error
Hi!
I have been trying to update to 0.74
First I tried via the server interface and ended up with it just saying "Connection Lost". So I SSH into the server and downloaded 0.75 and tried to install manually. This was the output:
sudo dpkg -i Repetier-Server-0.75.0-Linux.deb (Reading database ... 86256 files and directories currently installed.)
Preparing to replace repetier-server 0.75.0 (using Repetier-Server-0.75.0-Linux.deb) ...
Uninstall Repetier-Server
[ ok ] Stopping Repetier-Server: rsd.
Unpacking replacement repetier-server ...
Setting up repetier-server (0.75.0) ...
Install Repetier-Server
You may see warnings about groups. These can be ignored.
The user `repetierserver' is already a member of `tty'.
adduser: The group `intserial' does not exist.
adduser: The group `ugpio' does not exist.
[....] Starting Repetier-Server: rsdIllegal instruction
failed!
dpkg: error processing repetier-server (--install):
subprocess installed post-installation script returned error exit status 132
Errors were encountered while processing:
repetier-server
Any suggestions? I had the previous version installed before trying to update.
Many thanks
failed!
repetier-server
Many thanks
That should say 0.75 sorry!
0.70.1 has installed fine
I just tried to load 0.75.1 on a RaspberyPi 1, downloaded the armel version, installed it and got the same result as Snupple.
If I try to run the RepetierServer executable directly then I get an "Illegal Instruction" error.
Rolling back to armel 0.70.1 works fine.
Patrick
One contains a Jessie with Repetier-Server 0.75.1 armhf and runs fine.
One contains a Jessie-Lite with Repetier-Server 0.75.01 armhf, but it doesn't run.
After systemctl status RepetierServer.service
RepetierServer.service - LSB: Init Script for Repetier-Server
Loaded: loaded (/etc/init.d/RepetierServer)
Active: failed (Result: exit-code) since blabla
Process: 659 ExecStart=/etc/init.d/RepetierServer start (code=exited, status=132)
which packet is missing?
doesn't run. Both files are in their directories
sudo /etc/init.d/RepetierServer start -c /usr/local/Repetier-Server/etc/RepetierServer.xml
Same error like above
nothing happens -
pi@raspberrypi:~ $ sudo strace /usr/local/Repetier-Server/bin/RepetierServer -c /usr/local/Repetier-Server/etc/RepetierServer.xml
execve("/usr/local/Repetier-Server/bin/RepetierServer", ["/usr/local/Repetier-Server/bin/R"..., "-c", "/usr/local/Repetier-Server/etc/R"...], [/* 14 vars */]) = 0
brk(0) = 0x2915000
uname({sys="Linux", node="raspberrypi", ...}) = 0
access("/etc/ld.so.nohwcap", F_OK) = -1 ENOENT (No such file or directory)
mmap2(NULL, 8192, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_ANONYMOUS, -1, 0) = 0xb6f61000
access("/etc/ld.so.preload", R_OK) = 0
open("/etc/ld.so.preload", O_RDONLY|O_CLOEXEC) = 3
fstat64(3, {st_mode=S_IFREG|0644, st_size=42, ...}) = 0
mmap2(NULL, 42, PROT_READ|PROT_WRITE, MAP_PRIVATE, 3, 0) = 0xb6f60000
close(3) = 0
open("/usr/lib/arm-linux-gnueabihf/libarmmem.so", O_RDONLY|O_CLOEXEC) = 3
read(3, "\177ELF\1\1\1\0\0\0\0\0\0\0\0\0\3\0(\0\1\0\0\0h\5\0\0004\0\0\0"..., 512) = 512
lseek(3, 17960, SEEK_SET) = 17960
read(3, "\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0"..., 960) = 960
lseek(3, 17696, SEEK_SET) = 17696
read(3, "A.\0\0\0aeabi\0\1$\0\0\0\0056\0\6\6\10\1\t\1\n\3\f\1\22\4\24"..., 47) = 47
fstat64(3, {st_mode=S_IFREG|0644, st_size=18920, ...}) = 0
mmap2(NULL, 83236, PROT_READ|PROT_EXEC, MAP_PRIVATE|MAP_DENYWRITE, 3, 0) = 0xb6f1f000
mprotect(0xb6f24000, 61440, PROT_NONE) = 0
mmap2(0xb6f33000, 4096, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_FIXED|MAP_DENYWRITE, 3, 0x4000) = 0xb6f33000
mprotect(0xbeecd000, 4096, PROT_READ|PROT_WRITE|PROT_EXEC|PROT_GROWSDOWN) = 0
close(3) = 0
munmap(0xb6f60000, 42) = 0
open("/etc/ld.so.cache", O_RDONLY|O_CLOEXEC) = 3
fstat64(3, {st_mode=S_IFREG|0644, st_size=27625, ...}) = 0
mmap2(NULL, 27625, PROT_READ, MAP_PRIVATE, 3, 0) = 0xb6f5a000
close(3) = 0
open("/lib/arm-linux-gnueabihf/librt.so.1", O_RDONLY|O_CLOEXEC) = 3
read(3, "\177ELF\1\1\1\3\0\0\0\0\0\0\0\0\3\0(\0\1\0\0\0000\30\0\0004\0\0\0"..., 512) = 512
lseek(3, 25352, SEEK_SET) = 25352
read(3, "\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0"..., 1320) = 1320
lseek(3, 24964, SEEK_SET) = 24964
read(3, "A0\0\0\0aeabi\0\1&\0\0\0\0056\0\6\6\10\1\t\1\n\2\22\4\23\1\24"..., 49) = 49
fstat64(3, {st_mode=S_IFREG|0644, st_size=26672, ...}) = 0
mmap2(NULL, 90684, PROT_READ|PROT_EXEC, MAP_PRIVATE|MAP_DENYWRITE, 3, 0) = 0xb6f08000
mprotect(0xb6f0e000, 61440, PROT_NONE) = 0
mmap2(0xb6f1d000, 8192, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_FIXED|MAP_DENYWRITE, 3, 0x5000) = 0xb6f1d000
close(3) = 0
open("/lib/arm-linux-gnueabihf/libpthread.so.0", O_RDONLY|O_CLOEXEC) = 3
read(3, "\177ELF\1\1\1\0\0\0\0\0\0\0\0\0\3\0(\0\1\0\0\0lY\0\0004\0\0\0"..., 512) = 512
lseek(3, 120788, SEEK_SET) = 120788
read(3, "\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0"..., 1520) = 1520
lseek(3, 86420, SEEK_SET) = 86420
fstat64(3, {st_mode=S_IFREG|0755, st_size=122308, ...}) = 0
mmap2(NULL, 160316, PROT_READ|PROT_EXEC, MAP_PRIVATE|MAP_DENYWRITE, 3, 0) = 0xb6ee0000
mprotect(0xb6ef4000, 65536, PROT_NONE) = 0
mmap2(0xb6f04000, 8192, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_FIXED|MAP_DENYWRITE, 3, 0x14000) = 0xb6f04000
mmap2(0xb6f06000, 4668, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_FIXED|MAP_ANONYMOUS, -1, 0) = 0xb6f06000
close(3) = 0
open("/lib/arm-linux-gnueabihf/libdl.so.2", O_RDONLY|O_CLOEXEC) = 3
read(3, "\177ELF\1\1\1\0\0\0\0\0\0\0\0\0\3\0(\0\1\0\0\0\220\t\0\0004\0\0\0"..., 512) = 512
lseek(3, 8660, SEEK_SET) = 8660
read(3, "\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0"..., 1160) = 1160
lseek(3, 8328, SEEK_SET) = 8328
fstat64(3, {st_mode=S_IFREG|0644, st_size=9820, ...}) = 0
mmap2(NULL, 73912, PROT_READ|PROT_EXEC, MAP_PRIVATE|MAP_DENYWRITE, 3, 0) = 0xb6ecd000
mprotect(0xb6ecf000, 61440, PROT_NONE) = 0
mmap2(0xb6ede000, 8192, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_FIXED|MAP_DENYWRITE, 3, 0x1000) = 0xb6ede000
close(3) = 0
open("/usr/lib/arm-linux-gnueabihf/libstdc++.so.6", O_RDONLY|O_CLOEXEC) = 3
read(3, "\177ELF\1\1\1\3\0\0\0\0\0\0\0\0\3\0(\0\1\0\0\0xk\4\0004\0\0\0"..., 512) = 512
lseek(3, 808332, SEEK_SET) = 808332
read(3, "\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0"..., 1280) = 1280
lseek(3, 807760, SEEK_SET) = 807760
read(3, "A.\0\0\0aeabi\0\1$\0\0\0\0056\0\6\6\10\1\t\1\n\2\22\4\24\1\25"..., 47) = 47
fstat64(3, {st_mode=S_IFREG|0644, st_size=809612, ...}) = 0
mmap2(NULL, 900808, PROT_READ|PROT_EXEC, MAP_PRIVATE|MAP_DENYWRITE, 3, 0) = 0xb6df1000
mprotect(0xb6eb2000, 61440, PROT_NONE) = 0
mmap2(0xb6ec1000, 24576, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_FIXED|MAP_DENYWRITE, 3, 0xc0000) = 0xb6ec1000
mmap2(0xb6ec7000, 24264, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_FIXED|MAP_ANONYMOUS, -1, 0) = 0xb6ec7000
close(3) = 0
open("/lib/arm-linux-gnueabihf/libm.so.6", O_RDONLY|O_CLOEXEC) = 3
read(3, "\177ELF\1\1\1\0\0\0\0\0\0\0\0\0\3\0(\0\1\0\0\0p<\0\0004\0\0\0"..., 512) = 512
lseek(3, 434644, SEEK_SET) = 434644
lseek(3, 434312, SEEK_SET) = 434312
fstat64(3, {st_mode=S_IFREG|0644, st_size=435804, ...}) = 0
mmap2(NULL, 4096, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_ANONYMOUS, -1, 0) = 0xb6f59000
mmap2(NULL, 499856, PROT_READ|PROT_EXEC, MAP_PRIVATE|MAP_DENYWRITE, 3, 0) = 0xb6d76000
mprotect(0xb6ddf000, 65536, PROT_NONE) = 0
mmap2(0xb6def000, 8192, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_FIXED|MAP_DENYWRITE, 3, 0x69000) = 0xb6def000
close(3) = 0
open("/lib/arm-linux-gnueabihf/libgcc_s.so.1", O_RDONLY|O_CLOEXEC) = 3
read(3, "\177ELF\1\1\1\0\0\0\0\0\0\0\0\0\3\0(\0\1\0\0\0`\321\0\0004\0\0\0"..., 512) = 512
lseek(3, 116400, SEEK_SET) = 116400
read(3, "\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0"..., 1120) = 1120
lseek(3, 116072, SEEK_SET) = 116072
fstat64(3, {st_mode=S_IFREG|0644, st_size=117520, ...}) = 0
mmap2(NULL, 181664, PROT_READ|PROT_EXEC, MAP_PRIVATE|MAP_DENYWRITE, 3, 0) = 0xb6d49000
mprotect(0xb6d66000, 61440, PROT_NONE) = 0
mmap2(0xb6d75000, 4096, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_FIXED|MAP_DENYWRITE, 3, 0x1c000) = 0xb6d75000
close(3) = 0
open("/lib/arm-linux-gnueabihf/libc.so.6", O_RDONLY|O_CLOEXEC) = 3
read(3, "\177ELF\1\1\1\0\0\0\0\0\0\0\0\0\3\0(\0\1\0\0\0L\204\1\0004\0\0\0"..., 512) = 512
lseek(3, 1239936, SEEK_SET) = 1239936
read(3, "\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0"..., 2840) = 2840
lseek(3, 1236500, SEEK_SET) = 1236500
read(3, "A.\0\0\0aeabi\0\1$\0\0\0\0056\0\6\6\10\1\t\1\n\2\22\4\23\1\24"..., 47) = 47
fstat64(3, {st_mode=S_IFREG|0755, st_size=1242776, ...}) = 0
mmap2(NULL, 1312152, PROT_READ|PROT_EXEC, MAP_PRIVATE|MAP_DENYWRITE, 3, 0) = 0xb6c08000
mprotect(0xb6d33000, 65536, PROT_NONE) = 0
mmap2(0xb6d43000, 12288, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_FIXED|MAP_DENYWRITE, 3, 0x12b000) = 0xb6d43000
mmap2(0xb6d46000, 9624, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_FIXED|MAP_ANONYMOUS, -1, 0) = 0xb6d46000
close(3) = 0
mmap2(NULL, 4096, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_ANONYMOUS, -1, 0) = 0xb6f58000
mmap2(NULL, 4096, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_ANONYMOUS, -1, 0) = 0xb6f57000
set_tls(0xb6f574c0, 0xb6f57bb8, 0xb6f64050, 0xb6f574c0, 0xb6f64050) = 0
mprotect(0xb6d43000, 8192, PROT_READ) = 0
mprotect(0xb6def000, 4096, PROT_READ) = 0
mmap2(NULL, 4096, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_ANONYMOUS, -1, 0) = 0xb6f56000
mprotect(0xb6ec1000, 16384, PROT_READ) = 0
mprotect(0xb6ede000, 4096, PROT_READ) = 0
mprotect(0xb6f04000, 4096, PROT_READ) = 0
mprotect(0xb6f1d000, 4096, PROT_READ) = 0
mprotect(0xb6f1f000, 20480, PROT_READ|PROT_WRITE) = 0
mprotect(0xb6f1f000, 20480, PROT_READ|PROT_EXEC) = 0
cacheflush(0xb6f1f000, 0xb6f24000, 0, 0x15, 0xbeecd2e0) = 0
mprotect(0xb6f63000, 4096, PROT_READ) = 0
munmap(0xb6f5a000, 27625) = 0
set_tid_address(0xb6f57068) = 2098
set_robust_list(0xb6f57070, 12) = 0
rt_sigaction(SIGRTMIN, {0xb6ee5434, [], SA_RESTORER|SA_SIGINFO, 0xb6c371a0}, NULL, 8) = 0
rt_sigaction(SIGRT_1, {0xb6ee52d8, [], SA_RESTORER|SA_RESTART|SA_SIGINFO, 0xb6c371a0}, NULL, 8) = 0
rt_sigprocmask(SIG_UNBLOCK, [RTMIN RT_1], NULL, 8) = 0
getrlimit(RLIMIT_STACK, {rlim_cur=8192*1024, rlim_max=RLIM_INFINITY}) = 0
--- SIGILL {si_signo=SIGILL, si_code=ILL_ILLOPC, si_addr=0x317146} ---
+++ killed by SIGILL +++
Hope it helps!
pi@raspberrypi:~ $ wget http://download.repetier.com/files/server/debian-armhf/Repetier-Server-0.75.1-Linux.deb
--2016-06-23 10:43:53-- http://download.repetier.com/files/server/debian-armhf/Repetier-Server-0.75.1-Linux.deb
Resolving download.repetier.com (download.repetier.com)... 85.25.211.28, 62.75.236.93, 85.25.197.98
Connecting to download.repetier.com (download.repetier.com)|85.25.211.28|:80... connected.
HTTP request sent, awaiting response... 200 OK
Length: 38638334 (37M) [application/octet-stream]
Saving to: ‘Repetier-Server-0.75.1-Linux.deb’
Repetier-Server-0.75.1-Linux.deb 100%[=====================================================================================================================================>] 36.85M 1.14MB/s in 29s
2016-06-23 10:44:27 (1.28 MB/s) - ‘Repetier-Server-0.75.1-Linux.deb’ saved [38638334/38638334]
pi@raspberrypi:~ $ sudo dpkg -i Repetier-Server-0.75.1-Linux.deb
Selecting previously unselected package repetier-server.
(Reading database ... 31136 files and directories currently installed.)
Preparing to unpack Repetier-Server-0.75.1-Linux.deb ...
Unpacking repetier-server (0.75.1) ...
Setting up repetier-server (0.75.1) ...
Adding user `repetierserver' to group `tty' ...
Adding user repetierserver to group tty
Done.
Synchronizing state for RepetierServer.service with sysvinit using update-rc.d...
Executing /usr/sbin/update-rc.d RepetierServer defaults
Executing /usr/sbin/update-rc.d RepetierServer enable
[ ok ] Starting RepetierServer (via systemctl): RepetierServer.service.
Processing triggers for systemd (215-17+deb8u4) ...
and it is working without problems. Can't say why yours is not except maybe a data corruption in the file. These were the only commands entered since installing Jessy Lite, no updates etc.
I did the following procedure two times.
Install Jessi-Lite on SD card
no failures while booting
Install Repetier Server ( directly/ console).
--2016-06-23 17:37:23-- http://download.repetier.com/files/server/debian-armhf/Repetier-Server-0.75.1-Linux.deb
Resolving download.repetier.com (download.repetier.com)... 62.75.236.93, 85.25.197.98, 85.25.211.28
Connecting to download.repetier.com (download.repetier.com)|62.75.236.93|:80... connected.
Repetier-Server-0.7 100%[=====================>] 36.85M 6.21MB/s in 6.2s
2016-06-23 17:37:29 (5.90 MB/s) - ‘Repetier-Server-0.75.1-Linux.deb’ saved [38638334/38638334]
Done.
[....] Starting RepetierServer (via systemctl): RepetierServer.serviceJob for RepetierServer.service failed. See 'systemctl status RepetierServer.service' and 'journalctl -xn' for details.
failed!
dpkg: error processing package repetier-server (--install):
repetier-server
pi@raspberrypi:~ $ systemctl status RepetierServer.service
â— RepetierServer.service - LSB: Init script for Repetier-Server
Active: failed (Result: exit-code) since Thu 2016-06-23 17:39:46 UTC; 3min 40s ago
pi@raspberrypi:~ $
after that error I investigate my raspberry.
My dealer sold me a Raspberry b+ as a 2. I'm really p..... off!
I tried it with the latest jessie-lite and the Repetier Server armel Version and it runs.
Thanks for your help!
all the other installed packages are armhf-packages
