Printer head starts printing too high
in CuraEngine
Cura raises the z axis to 15 mm before moving to the print place (to prevent scratching I think). Unfortunately, Repetier Host does not count this so my skirt/raft/brim is always 15 mm above the bed (this creates a lot of problems lol). I am using Cura separately and the start G-code is:
;Sliced at: {day} {date} {time}
;Basic settings: Layer height: {layer_height} Walls: {wall_thickness} Fill: {fill_density}
;Print time: {print_time}
;Filament used: {filament_amount}m {filament_weight}g
;Filament cost: {filament_cost}
;M190 S{print_bed_temperature} ;Uncomment to add your own bed temperature line
;M109 S{print_temperature} ;Uncomment to add your own temperature line
G21 ;metric values
G90 ;absolute positioning
M82 ;set extruder to absolute mode
M107 ;start with the fan off
G28 X0 Y0 ;move X/Y to min endstops
G28 Z0 ;move Z to min endstops
G1 Z15.0 F{travel_speed} ;move the platform down 15mm
G92 E0 ;zero the extruded length
G1 F200 E3 ;extrude 3mm of feed stock
G92 E0 ;zero the extruded length again
G1 F{travel_speed}
;Put printing message on LCD screen
M117 Printing...
Is there any way to move the extrude head down so I can actually print?
Maybe comment out the G1 Z15.0 F{travel_speed} ;move the platform down 15mm (this might result in the tape tearing on my bed...), or could I write code after it saying move down 15 mm after (if I were to do so, what would the g-code be?)
