Repetier Not Responding and Connecting
Please help me out asap I really want to get my printer running.
  • Any one???
  • Just bought a printrboard and could not follow the problems. Led is green (which might vary depending on manufacurer), I see port in hardware manager and can connect normally. The host hang happens, when the os connect function is called and does not return. So first try should be reboot windows to reinitalize driver. If it does not help deinstall driver and install latest driver again. Also make sure no other software is using that port at the same time.
  • How do you find out of another software is using the port?
