Recommended baud rate?
I am using a Raspberry Pi 2 Model B running Raspbian Jessie, which has been updated to the latest packages. It is running Repetier-Server Free, and controlling 3 WANHAO Duplicator i3 3D Printers.
However, even with this entire setup, the prints stutter while they are running after about 5-15 minutes. Sometimes it's a small stutter, sometimes it simply stops for 10 seconds-several minutes. The prints themselves do not stop, and Repetier-Server does not show any errors or glitches in the log.
I am wondering if this is a problem with the baud rate configured on the serial port of the printers/Raspberry Pi.
From what I am reading online, others have had this problem, but that was in earlier releases, and in the later releases (in the update notes), they mentioned that they fixed these problems. Why, then, am I still having them?
Please respond as soon as possible.
Thanks.
