repetier serveur lite et speeder pad
Bonjour,
est-il possible de mettre Repetier serveur lite sur un Speeder pad de chez Flsun ?
Hello,
Is it possible to install Repetier Server lite on a Flsun Speeder Pad ?
Sincerely,
Robert
  • It could be possible - the processor is at least supported. I can not help much here - I do not have one and if you need the existing functionality it might break if you modify important files. In theory you just log in and install the arm 32 bit package and it should run on port 3344. If you want the display to show our touch interface you must tweak the the pad to show our url instead.
