PROBLEM with sending g code program from repetier server from cmd console to biobot using curl -X..
I have a problem sending gcode program to biobot printer repetier server from cmd console using commands
from bash script file :
#!/bin/bash
API_KEY="b4b6dbb4-2f1c-4afb-82ba-e7a02f41afb9"
PRINTER_NAME="printer"
GCODE_COMMAND="G1 X10 Y10"
curl -X POST "http://localhost:3344/printer/send" \
-H "Content-Type: application/json" \
-H "apikey: $API_KEY" \
-d "{\"printer\":\"$PRINTER_NAME\", \"data\":\"$GCODE_COMMAND\"}"
I get a message :
"The requested feature requires a user session with adequate permissions."
I had a message on the older version of the repetier server before
"error printer offline or usage error"
Can I ask for help ?
