Repetier-Server Drag and Drop
I decided to make a drag and drop feature so I didn't have to keep changing the upload folder, and so I could add multiple files at once.
If you do decide to use this, make sure to make a backup of app.min.js, printer.print.php, and uploadGCode.php.
Folder to put this should be located at C:\Program Files (x86)\Repetier-Server\
I made other changes to the UI, but without my index.php file, they shouldn't show up. If this causes any problems, let me know and I'll restore my backups and make just the drag and drop changes.
https://www.foregotten.net/repetier-server/Repetier-Server.zip This extracts right into the Repetier-Server Folder. Don't forget to backup the files as you will be prompted to overwrite them.
  • What is the difference to existing drag and drop? I mean existing version also has multi file drag and drop if you drag files on the button.
