How to transfer all RepetierHost settings to a new installation
Hi, I have a clean install of RepetierHost on another computer. How can I transfer all my printer settings from my working RepetierHost installation to the new system without having to manually go thru and redo them all again. There is no "Export\Save Settings" menu option. I tried copying the users\???\Appdata\local\repetierhost folder but that didn't update my printer shape settings.
  • It is in registry HKLM/Software/repetier You can export it ussing regedit but that is more for experts.
    Also this does not copy the slicer settings. These are either in work director (CuraEngine) or un HOME/AppData/Roaming/prusa... I think it was.
  • 1. Config files should be copied. The backup folder is located at C:\Users\YourUser\AppData\Local\RepetierHost.
    2. Export Printer Settings: Select Printer Settings > Export in RepetierHost.
    3. Paste the backed-up files into the new installation directory in order to restore Settings.
    4. Check EEPROM Settings: Verify EEPROM values if you are using Repetier-Firmware.
    5. Reinstall Drivers: Verify that the serial and USB drivers correspond to your printer.
    6. Check G-code Scripts: In Printer Settings, look for start/end G-code.
    7. Sync Slicer Profiles: If necessary, make a copy of the slicer configuration files.
  • Hi,
    You can export it using regedit.
  • After transferring the files, restart RepetierHost on the new system. Your printer settings should now be available, and you can verify that everything has been transferred correctly. Check https://forum.repetier.com/discussion/11737/how-to-transfer-all-repetierhost-settings-to-a-new-installation age of war
