Server-Monitor shows total layers as "0"
... I use the server monitor on an old netbook as an independent display.
I noticed that the monitor always shows the total number of layers to be printed as -0-.
Have I missed something or is this a BUG?
This doesn't seem to always occur. I've just started a new print and it's displayed correctly.
Mails from the system repetier.com don't have a DKIM
I'm now paying particular attention to whether I can somehow recognize a pattern in which context the problem occurs, but unfortunately I haven't had any success so far.
This morning I started a new print. The monitor was already running during this time. Nevertheless, the monitor again shows the total number of layers as "0"; the server's WEB GUI, however, shows the total number of layers correctly, as before.
After starting the third print today, the number of layers was at "0" as before.
However, the print failed, so I had to cancel the print on the server (direct at the PI, not via WEB-GUI) and start again.
The number of layers has been displayed since then; the monitor was running all day with...
When it happens (like it did again this morning), the total number of layers is ALWAYS "0".
In the terminal window, it always shows...
