Connect Creality K2 Plus (runs on Klipper) to repetier
I have a Creality K2 Plus and want to connect it to repetier.
Connection via USB Port is not working. I connected the printer to LAN now and want to integrate the printer that way.
I am a newbie regarding network stuff and would love to get some help:D
So I am already able to connect to the webinterface. The web interface is fluidd.
There I saw, that my printer runs on Klipper. Does anybody know how to connect the printer to repetier? This wholer klipper software is very confusing to me.
Thanks in advance
Jake
  • At the moment we can only connect to klipper serial port/api port directly. What you have is klipper with moonraker providing network connection which is different. Support for this is planned but not implemented yet.
  • Thank you for the fast response!
    Can you think of another possibility on how i can connect my K2 Plus to repetier?
  • You would need a lot of linux knowledge to do this. You could add a serial to tcp forwarder to the K2, but I can con say how this should be done and also not sure it would be a solution that is stable enough. Better wait for the moonraker connector so it works out of the box.
  • Okay, thank you. What do you think how long does your development for moonraker connector roughly take? Few months or rather something for next year?
  • A few month is realistic. Once bambu connector which we are working on works, most required changes are already included so new connectors should be quicker to implement.
  • Wow, Will be watching out for this - would be highly motivated to kick Creality software. Have 2 K2's but disappointed in Creality "No-" customer service. My previous home-built machine some 12 years old ran on Repetier Never had issues. (Found this discussion on Web and jumped right back....)
