Version portable / portable version
Bonjour existe-il une version portable (installation sur clé USB ) de Repetier host ?
Pour avoir tous mes réglages de slicer avec moi, et juste remettre à jour l'imprimante quand je me déplace avec ma clé PortableApps
Hello, is there a portable version (installation on USB key) of Repetier host?
To have all my slicer settings with me, and just update the printer when I move with my PortableApps key
  • No, this is not possible. Slicers are independent and store data on special folders and host also uses registry and special folders for work and settings. So even if you have the pure executeable which you can start also from usb you need all settings on disk in special folders.
