Backup aborted due a failed bakcup of report file
in Bug Reports
I'm having problems with backups as they always stop at the same report file. I've turned off report generation but it's still there.
Please add a button to delete all reports.
Or allow downloading the configuration of each printer separately from its reports.
sudo rm /var/lib/Repetier-Server/reports/*.pdf
If it always stops at one report it might be a file system issue, so hope delete helps.
Adding a delete all in config is a good idea if someone decides to remove them.
