2 models, 2 tools one at the time
I’m using CuraEngine from the command line and need to generate G-code for two models, each printed with a different tool, one at a time. I understand this isn’t directly possible in the Cura Ultimaker software. Is there a way to bypass this limitation using CuraEngine from the command line?
  • No, I do not see how this could be done on command line. The bundled version has no sequential printing I think otherwise it would be in settings.
