power on graph extruder
Bonjour ,
sur le graphique de l'extrudeur le pourcentage d'alimentation ne s'affiche pas
translate by google because I am french and old :)
on the extruder graph the power percentage is not displayed
2 emotion tech Micro Delta Rework
Raspberry PI 4Go
Repetier host 2.3.2
Repetier server free 1.4.18
Repetier server Monitor 1.4.7
  • This mainly depends on the printer firmware. Only if power is reported we show the power graph as green background. One case I know is klipper without api connection. In g-code mode klipper will not report power only via api object model.
  • merci pour votre réponse
     je vais faire sans cette information, dommage car celui du bed est affiché, c'est pour celà que ça m'a interrogé
    Thank for your response
    I'm going to do without this information, too bad because that of the bed is displayed, that's why it questioned me.
    Two emotion tech, Micro Delta Rework firmware "smoothieware"
    Raspberry PI 4Go
    Repetier host 2.3.2
  • You can check in console when you disable temperature filter you see what smoothieware reports. If you see that it reports power please copy paste some lines here. Maybe ther format is not correctly supported. Unfortunately not all firmwares do it the same.
  • j'ai pris ça dans Repetier host pendant qu'il imprime
     I took this from Repetier host
    15:11:11.581 : ok (N104470)
    15:11:11.628 : ok (N104471)
    15:11:11.628 : ok (N104472)
    15:11:11.628 : ok (N104473)
    15:11:11.722 : ok (N104474)
    15:11:11.722 : ok (N104475)
    15:11:11.925 : ok (N104476)
    15:11:11.941 : ok T:227.4 /225.0 @29 B:70.0 /70.0 @110 ; (N104477)
    15:11:12.035 : ok (N104478)
    15:11:12.035 : ok (N104479)
    15:11:12.035 : ok (N104480)
    15:11:12.035 : ok (N104481)
    15:11:12.035 : ok (N104482)
    15:11:12.035 : ok (N104483)
    15:11:12.035 : ok (N104484)
  • et ça dans repetier server
    ok (N111584)
    Send:14:14:17.080: N111585 G0 X-5.000 Y9.499
    Recv:14:14:17.089: ok (N111585)
    Send:14:14:17.089: N111586 G1 F3000 X-5.000 Y-9.408 E2356.02207
    Recv:14:14:17.597: ok (N111586)
    Send:14:14:17.597: N111587 M105
    Recv:14:14:17.598: ok T:228.6 /225.0 @0 B:70.0 /70.0 @38 (N111587)
    Send:14:14:17.598: N111588 G0 F9000 X-4.926 Y-9.266
    Recv:14:14:17.617: ok (N111588)
    Send:14:14:17.617: N111589 G0 X-6.269 Y-9.196
    Recv:14:14:17.619: ok (N111589)
    Send:14:14:17.619: N111590 G0 X-6.890 Y-10.025
    Recv:14:14:17.627: ok (N111590)
  • edited November 2024
    M105
    Recv:15:29:00.834: ok T:232.0 /229.0 @0 B:70.0 /70.0 @41 (N243913)
    Send:15:29:00.834: N243914 G0 F9000 X22.763 Y9.505
    Recv:15:29:00.842: ok (N243914)
    Send:15:29:00.842: N243915 G1 F4080 X-2.452 Y-15.710 E7837.74357
    Recv:15:29:01.376: ok (N243915)
    Send:15:29:01.376: N243916 G0 F9000 X-3.668 Y-15.158
    Recv:15:29:01.386: ok (N243916)
    Send:15:29:01.386: N243917 G1 F4080 X22.022 Y10.532 E7838.71028
    Recv:15:29:01.932: ok (N243917)
    Send:15:29:01.932: N243918 M105
    Recv:15:29:01.933: ok T:232.0 /229.0 @0 B:70.0 /70.0 @107 (N243918)
    Send:15:29:01.933: N243919 G0 F9000 X21.210 Y11.487
    Recv:15:29:01.941: ok (N243919)
    Send:15:29:01.941: N243920 G1 F4080 X-4.893 Y-14.616 E7839.69252
    Recv:15:29:02.495: ok (N243920)
    Send:15:29:02.495: N243921 G0 F9000 X-6.091 Y-14.045
    Recv:15:29:02.505: ok (N243921)
    Send:15:29:02.505: N243922 G1 F4080 X20.322 Y12.368 E7840.68643
    Recv:15:29:03.062: ok (N243922)
    Send:15:29:03.062: N243923 M105
    Recv:15:29:03.064: ok T:231.7 /229.0 @255 B:70.0 /70.0 @189 (N243923)
    Send:15:29:03.064: N243924 G0 F9000 X24.646 Y6.085
    j'espère que je ne me trompe pas
    I hope I'm not wrong
    https://ibb.co/wYyhhZG  photo
    https://ibb.co/GnnfX0d
  • Looks like there is a power for extruder but it is not visible. Often the value is 0 but not all the time so I would expect to see some spikes at least. I will investigate further.
  • Ok found it. Normally it is @:value but smoothieware uses @value and for T the case was not added. Should work in 1.5.0.
  • thank B)  you are the best
    tout le reste fonctionne à merveille
    everything else works perfectly
    https://ibb.co/58ycBkQ
  • Bonjour , c'est encore moi !
    Je suppose que dans Repetier host  onglet "courbe de température" les graphiques "sortie extrudeur" et "sortie plateau" c'est le même problème ?
    Hello, it’s me again!
    I suppose that in Repetier host tab "temperature curve" the graphs "output extruder"
    and "output bed" it's the same problem ?
    screen shot
    https://ibb.co/4mn0QFJ
  • Likely, have added it to my checklist for next update.
