my printer doesn't respond to the repetier command
Hi my Flying Bear Ghost 5 doesn't run the command that I give from repetier host, the error is:
15:36:15.650 : No start signal detected - forcing start
15:36:55.765 : Communication timeout - reset send buffer block
15:37:31.792 : No start signal detected - forcing start
15:38:11.844 : Communication timeout - reset send buffer block
15:38:51.939 : Communication timeout - reset send buffer block
15:39:32.009 : Communication timeout - reset send buffer block
15:40:12.076 : Communication timeout - reset send buffer block
15:40:52.170 : Communication timeout - reset send buffer block
15:41:32.256 : Communication timeout - reset send buffer block
15:42:12.342 : Communication timeout - reset send buffer block
Can anyone help me?
Did you change anything since it worked? Could there be a connection?
What do you mean with local host? Repetier-Host is not a remote software. If you use Repetier-Server on same pc make sure no other software like host tries to connect, use same baud rate, port etc as you use in host and make sure the firmware is set correctly.
