Repetier appimage does not run on lmde 6
LD_LIBRARY_PATH = /tmp/.mount_RepetiwIUsXV/usr/lib:
MONO_PATH = /tmp/.mount_RepetiwIUsXV/usr/lib
Unhandled Exception:
System.TypeInitializationException: The type initializer for 'System.Windows.Forms.WindowsFormsSynchronizationContext' threw an exception. ---> System.TypeInitializationException: The type initializer for 'System.Windows.Forms.ThemeEngine' threw an exception. ---> System.TypeInitializationException: The type initializer for 'System.Drawing.GDIPlus' threw an exception. ---> System.DllNotFoundException: libgdiplus.so.0 assembly:<unknown assembly> type:<unknown type> member:(null)
at (wrapper managed-to-native) System.Drawing.GDIPlus.GdiplusStartup(ulong&,System.Drawing.GdiplusStartupInput&,System.Drawing.GdiplusStartupOutput&)
at System.Drawing.GDIPlus..cctor () [0x000b0] in <855fb33ee0ce444c9734eb0dae83c706>:0
--- End of inner exception stack trace ---
at System.Drawing.StringFormat..ctor (System.Drawing.StringFormatFlags options, System.Int32 language) [0x00011] in <855fb33ee0ce444c9734eb0dae83c706>:0
at System.Drawing.StringFormat..ctor () [0x00000] in <855fb33ee0ce444c9734eb0dae83c706>:0
at (wrapper remoting-invoke-with-check) System.Drawing.StringFormat..ctor()
at System.Windows.Forms.ThemeWin32Classic.ResetDefaults () [0x0001f] in <25c2bdf9d79a43a599eb46bd15cd77fb>:0
at System.Windows.Forms.ThemeWin32Classic..ctor () [0x00006] in <25c2bdf9d79a43a599eb46bd15cd77fb>:0
at System.Windows.Forms.ThemeEngine..cctor () [0x00012] in <25c2bdf9d79a43a599eb46bd15cd77fb>:0
at System.Windows.Forms.SystemInformation.get_MenuAccessKeysUnderlined () [0x00000] in <25c2bdf9d79a43a599eb46bd15cd77fb>:0
at System.Windows.Forms.Control..ctor () [0x000d6] in <25c2bdf9d79a43a599eb46bd15cd77fb>:0
at (wrapper remoting-invoke-with-check) System.Windows.Forms.Control..ctor()
at System.Windows.Forms.WindowsFormsSynchronizationContext..cctor () [0x00000] in <25c2bdf9d79a43a599eb46bd15cd77fb>:0
at System.Windows.Forms.Control..ctor () [0x0000d] in <25c2bdf9d79a43a599eb46bd15cd77fb>:0
at System.Windows.Forms.ScrollableControl..ctor () [0x00000] in <25c2bdf9d79a43a599eb46bd15cd77fb>:0
at System.Windows.Forms.ContainerControl..ctor () [0x0000e] in <25c2bdf9d79a43a599eb46bd15cd77fb>:0
at System.Windows.Forms.Form..ctor () [0x00012] in <25c2bdf9d79a43a599eb46bd15cd77fb>:0
at RepetierHost.view.utils.SplashScreen..ctor () [0x00000] in <9a5f3ad3b87c46f4bf88150a6cb4c659>:0
at (wrapper remoting-invoke-with-check) RepetierHost.view.utils.SplashScreen..ctor()
at RepetierHost.view.utils.SplashScreen.run () [0x00049] in <9a5f3ad3b87c46f4bf88150a6cb4c659>:0
at RepetierHost.Program.Main (System.String[] args) [0x0000b] in <9a5f3ad3b87c46f4bf88150a6cb4c659>:0
[ERROR] FATAL UNHANDLED EXCEPTION: System.TypeInitializationException: The type initializer for 'System.Windows.Forms.WindowsFormsSynchronizationContext' threw an exception. ---> System.TypeInitializationException: The type initializer for 'System.Windows.Forms.ThemeEngine' threw an exception. ---> System.TypeInitializationException: The type initializer for 'System.Drawing.GDIPlus' threw an exception. ---> System.DllNotFoundException: libgdiplus.so.0 assembly:<unknown assembly> type:<unknown type> member:(null)
This is the error when i am trying to run it from terminal on lmde from someone told me:
"It appears as if
"It appears as if
libgdiplus.so.0
is a dependency. Try installing it with"sudo apt install libgdiplus
but not working
result of install
Reading package lists... Done
Building dependency tree... Done
Reading state information... Done
libgdiplus is already the newest version (6.1+dfsg-1+b1).
The following package was automatically installed and is no longer required:
libu2f-udev
Use 'sudo apt autoremove' to remove it.
0 upgraded, 0 newly installed, 0 to remove and 0 not upgraded.
